Thread: Multitronic CVT question
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Multitronic CVT question
    Mar 2008
    A, A
    Sorry if a FAQ but I'm confused: does my Multitronic use a torque converter or some form of friction system?
    I notice a big difference between my 2012 and previous 09 model. OK it has 7 more PS' but the drive feels MUCH better, especially during initial acceleration.
  2. Re: Multitronic CVT question
    Mar 2012
    Berkshire
    I believe the Audi system works using the "cone and belt" based CVT system. Think something like mountain bike gears.
    Good CVT explanation here: CVT - what the Continuously Variable Transmission is and how CVT works
  3. Re: Multitronic CVT question
    Feb 2007
    Good old Wikipedia also has what seems, to me anyway, a credible description -
    multitronic - Wikipedia, the free encyclopedia
  4. Multitronic CVT question
    Jul 2009
    Manchester
    I think that Audi have been continually improving the Multitronic. The latest one in the A6 is supposed to be a lot better than earlier ones which were criticised for a sort of "power boat" effect i.e.when you set off the engine jumped to high revs and stayed there. The latest one does not do that and is much more refined.
  5. Re: Multitronic CVT question
    Mar 2012
    Berkshire
    Mine tends to jump to around 2500-3000 and then gradually increase from there.
  6. Multitronic CVT question
    Mar 2008
    A, A
    Thanks for all the feedback, I understand how the gearbox itself works but wondered how the "clutch" works. It doesn't feel like a torque converter and I think I have read a reference here somewhere (can't find now) that its some form of friction based clutch.
    If it's not a torque converter how / why does it creep? And wouldn't it be a bad thing in lots of slow city traffic?
    Also, in terms of fuel economy, sitting stationary in gear reduces rpm by a few 100. popping it into neutral returns engine to slightly higher speed, is this better than sitting on a brake?
  7. Re: Multitronic CVT question
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    As with any automatic, it's OK to sit in gear for a short while but always better to knock it out of drive if stationary for more than 30 sec or so as eventually you can promote wear within the clutch drive. The creep factor has been engineered in to make the system more acceptable.
  8. Re: Multitronic CVT question
    jbanfie Guest
    It's a clutch!!!
    From
    Audi multitronic
    "Audi instead uses an oil-cooled multi-plate clutch which not only avoids the
    typical transmission losses of the torque converter, but also implements a
    variety of starting strategies. These are selected by the electronic control
    circuitry in accordance with the driver's preferences, as detected from how the
    accelerator pedal is being used. The electronic-control multi-plate clutch
    moreover offers the convenience feature of constant creep behaviour. "
    1 1 0
  9. Re: Multitronic CVT question
    BrianWM Guest
    I suspect it's basically the same as the clutch on the s-tronic, just a differenct gearbox connected to it. Mines the s-tronic and although I'd prefer a torque converter in stop start traffic, the clutch doesn't do too bad. I have a bit of an issue with reversing up hill though ! (see other thread)
    I'd like to know if the drag on the clutch, which is essential for the feel of the car, still happens with your foot firmly on the brake or when the hill hold is in operation. It'd be a pointless waste of energy, clutch lining and you'd think the software would know it isn't needed.
  10. Re: Multitronic CVT question
    Mar 2008
    A, A
    Quote Originally Posted by Whippy53 View Post
    ... The creep factor has been engineered in to make the system more acceptable.
    What does this mean, the system wouldn't creep like a classic auto so has had magic applied to make it look / feel like a classic auto?
    Geek in me has to ask: how?
  1. Multitronic/CVT problem
    By gosc4x4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-02-2011, 12:20 AM
  2. audi a4 multitronic(cvt)
    By k20a in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-06-2010, 11:27 AM
  3. CVT=Multitronic or?
    By v_j_r in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2008, 10:29 AM
  4. CVT Multitronic GearBox
    By obwos in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-08-2008, 05:33 PM
  5. CVT /Multitronic confusion
    By norbet in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-06-2008, 12:17 PM
