Thread: Auxilary heater seem to work but gets blocked
  1. Auxilary heater seem to work but gets blocked
    May 2010
    sweden
    I have a Touran Tdi 2010. It has an aux heater. At first it was blocked to start and gott fault codes. I reset the fault codes and unblocks it, and it works, as far as I can see fine. It produces a lot of smoke, but it heats the engine and so on. But after a couple of trips (or days) it gets blocked again. Anyone know what the problem is?
    Heres the fault codes that comes with the block:
    4 Faults Found:
    01406 - No Flame
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 172
    Mileage: 114587 km
    Time Indication: 0
    Freeze Frame:
    Start
    Temperature: 56.0°C
    Temperature: 56.0°C
    Voltage: 14.24 V
    01412 - Glow-Plug with Flame Monitoring (Q8)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 172
    Mileage: 114606 km
    Time Indication: 0
    Freeze Frame:
    Start
    Temperature: 55.0°C
    Temperature: 55.0°C
    Voltage: 14.09 V
    01407 - Flame Extinguished
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 172
    Mileage: 114626 km
    Time Indication: 0
    Freeze Frame:
    Start
    Temperature: 18.0°C
    Temperature: 16.0°C
    Voltage: 14.09 V
    02251 - Heater Unit Locked
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 114626 km
    Time Indication: 0
  2. Re: Auxilary heater seem to work but gets blocked
    May 2010
    sweden
    nobody that has any idea?
  3. Re: Auxilary heater seem to work but gets blocked
    46 Post(s)
    01406 - Ross-Tech Wiki
    02251 - Ross-Tech Wiki
    RT only have pages for the above two.
  1. Question Auxilary heater
    By snorhyvel in forum Touran - Sharan - Caravelle
    Last Post: 05-12-2012, 11:49 PM
  2. Auxilary heater relay J8
    By Alas in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2011, 12:11 PM
  3. Please Help touran auxilary heater
    By tractor fixer in forum Touran - Sharan - Caravelle
    Last Post: 06-01-2011, 08:54 PM
  4. Auxilary Heater
    By rally5 in forum Touareg
    Last Post: 30-10-2009, 01:12 AM
  5. How do you flush a heater matrix or tell if its blocked?
    By wibers in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-12-2008, 08:32 PM
