Thread: Audi a3 2.0 tdi flat spot sluggish
Results 1 to 10 of 10
  1. Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    Hi folks i have a 2007 2.0 tdi 140 and yesterday i noticed the car become unresponsive with the throttle following hard acceleration on a slip road felt as if the car would not go any faster no warning lights appeared and car was very flat,once the car was turned off and left for 10 minutes(while i called at a shop)the car was back to normal driving wise am quite puzzled as what it can be and as no fault light has come up not much to go on could this be the EGR valve or am i barking up the wrong tree any help would be great and thanks.
  2. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2012
    Coding Something
    How fast were you going flat out, rev numbers, etc all helps to aid replies.
  3. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    thanks for reply prob about 50/60 mph at a guess 5000 rpm i will try and mirror what happened again and try to recall speed revs etc thanks
  4. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2012
    Coding Something
    Cant be limp as wouldnt get upto 3k revs afaik.
  5. Re: Audi a3 2.0 tdi flat spot sluggish
    Feb 2009
    Glasgow UK
    Hey there,
    I wonder if looking at this may help to give you some ideas?
    http://www.google.co.uk/url?sa=t&rct...57316858,d.d2k
    Hope it helps some
  6. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    Thanks Jim some good reading there i will crack on,thank you.
  7. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    UPDATE ..EGR valve and mass air flow sensor cleaned and still the car has a acceleration problem car will go up to 2000 rpm and will very slowly rise but no power to accelerate this only happens now and then,say when i am trying to accelerate under load, pulled into a lay-by turned off ignition turned car back on right as rain any suggestions are very welcomed thanks everyone.just to inform no dash light again so cannot diagnose to an error code.
  8. Re: Audi a3 2.0 tdi flat spot sluggish
    Feb 2009
    Glasgow UK
    Hey Andy,
    don't know if any of this sounds similar or not, but have a look at my threads concerning my issues. Hopefully I'm wrong and way off the mark as my issue sounds potentially worse than yours, but I guess its something else to consider / rule out
    A6 2.0 Tdi ( 2007 - BRE ) In tank fuel pump location / how to
    Help needed reading VCDS scans
    Hopefully yours is an easy fix I can read about shortly
  9. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    Quote Originally Posted by JimC64 View Post
    Hey Andy,
    Hi Jim brilliant thread with some good ideas plenty for me to investigate as a starter but as you say i dont want to be throwing money at it and problem still apparent thanks again buddy.
  10. Re: Audi a3 2.0 tdi flat spot sluggish
    Jan 2013
    north wales
    Hey Andy,
    Thanks again Jim after reading various threads including yours i am still pondering over pump issues for starters,car always starts great no juddering etc smooth, its not all the time either that i am having this problem and the wife has never had it but she does not accelerate hard in the car fault must be electrical ???? for the problem to disappear following turning off of the car i am in the same boat as you as i dont mind going to dealer but to leave with a big bill and still problem persistent it does put me off once again thanks for your patience and time Andy.
  1. Bad flat spot 2.0pd tdi
    By Paschalc in forum 2.0TDi - Engine
    Last Post: 02-08-2010, 07:11 PM
  2. Replies: 3
    Last Post: 25-04-2010, 07:18 AM
  3. Question Engine flat spot on 1.4 TDI
    By nbolton in forum Polo - Derby - Lupo - Fox
    Last Post: 22-02-2010, 03:00 PM
  4. V6 Tdi intermitent flat spot/surge
    By CherryB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2007, 12:25 PM
  5. TDi Flat spot...
    By chrisp in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-01-2007, 12:02 PM
