Thread: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
Page 32 of 38 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 372
  1. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Jan 2018
    BB
    which Lifeguard oil is best for JMQ gearbox ?
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 K HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0040
    Revision: --H01--- Serial number: 4223212
    Coding: 0000001
    Shop #: WSC 02331 785 00200
    VCID: 2D5116E8B427BE2E0A-8078
    No fault code found.
  2. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    8 Post(s)
    Lifeguard6 for 6 speed lifeguard 8 for 8 speeds. Or equivalents
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  3. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2016
    London
    18 Post(s)
    Quote Originally Posted by jubbly View Post
    No. Tiptronic software will determine the type of oil. Pre facelifted was lifeguard 6 and facelifted was 8. You can use 8 on pre facelifted but you need to flash newer soft
    Sent from my SM-G950F using Tapatalk
  4. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Jan 2018
    BB
    Quote Originally Posted by niedzial1983 View Post
    Thanks niedzial for your answer.
    I have also contacted ZF Services UK Ltd and received following answer:
    I can confirm your transmission is already equipped with lifeguard 8 and the relevant software. The difference between the Lifeguard 6 and 8 fluids is the additive pack that changes the way the oil operates.
    My A6 allroad is MY 2007 pre-facelift.
    I am not sure if i can fully trust ZF guy because i have no idea how he know which software is flashed into my gearbox...I just send him VIN number and photo of gearbox label
  5. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2016
    London
    18 Post(s)
    Quote Originally Posted by ESXX View Post
    You can check soft etc with vcds
  6. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2008
    40 Post(s)
    I would imagine the gearbox plate is like a cars vin and will tell him everything thats in the box incl the software
  7. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2016
    Cardigan
    6 Post(s)
    Hi all,
    I have this gearbox in my 2008 A6 3.0tdi and I've noticed that at lowish speeds, below 40mph, the rev needle fluctuates 200-400rpm. This may not sound a lot but having owned loads of different cars over the years it's the first time I've really notice it.
    For example if I'm driving through a 30mph limit with the cruise on the needle fluctuates although he car maintains the same speed. In my 2011 Mercedes C220 with 7g box the needle stays perfectly still.
    On start up the needle moves around more than I'm used to too. At least until warm.
    I've run VCDS which threw up 4 failed glow plugs. I've replaced these and the 'problem' is still there. There's no other error codes on engine or gearbox.
    I'm not quite sure if I can fell the fluctuations as it might be psychosomatic, so to speak, in that I see the needle move and then think I feel a difference in the car!
    I had the gearbox filter and oil changed last week and it's still there.
    Car is the 3.0tdi with 88k on the clock and full Audi history. Which, incidentally, doesn't really fill me with confidence because I have to loosen the manifold cover to free up the no.1 cylinder glow plug cable as it was trapped under the cover!!
    Is this just a peculiar trait associated with this engine and/or gearbox?
    Any thoughts gratefully received!
    Thanks.
    James
  8. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Aberdeen
    63 Post(s)
    Hi James,
    Sounds like it might be the torque coverter but could be injector, throttle body etc.
    What oil did they use? It should be lifeguard 8 (but check on this). If you can give ZF the gearbox code they can tell you the corrrect oil.
    The box is very good and should be really steady. Gearbox specialists should manage to read the gearbox ecu for faults - these won't show on VCDS.
  9. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Jul 2015
    Staffs
    46 Post(s)
    If its 'only' the revs needle fluctuating with nothing felt or heard is it truly an issue?
    Ian
    A4 B6 Avant Nogaro Blue
  10. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2016
    London
    18 Post(s)
    I have the same flacuation .i have visit tomorrow booked with zf to check so will let you know . Its defo not engine
  1. A6 TDi 2.7 Quattro Tiptronic - electrical gremlins
    By Slaine in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2010, 10:13 AM
  2. Please Help A4 2.5 tdi quattro sport tiptronic problem
    By rts1275 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2010, 01:23 AM
  3. Jerky Gearbox - A6 2.5 TDI Quattro Tiptronic.
    By jahgti1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-11-2008, 12:57 AM
  4. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-11-2008, 06:31 PM
  5. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-11-2008, 06:18 PM
