Thread: Boot latch problems,please help!!
  1. Boot latch problems,please help!!
    May 2009
    England
    Hello all,Im after a bit expert advice.Im having a problem with my boot, initially the problem was that the boot wouldn't latch shut what so ever so even when the central locking was pressed,the boot would not shut so was constantly unlocked which showed up on the display as open. I assumed the solenoid had gone but after a bit of research it seems that it is quite common due to water coming from the washer pipe and/or rear wiper grommet which also has been known to set off the alarm randomly (this happens to mine also as apparently it sets off the boot sensor). The day after the problem I took off all the trim inside and manually locked the boot,the dash still showed it was open.
    When I had a bit more time I investigated further,I had to now unlock the boot from the inside by pulling the rod which attached to the solenoid (I had to slacken off the solenoid from the chassis to be able to do this).
    I then looked for obvious signs of any damage in the wiring but was unable to see any,although there were a few drops of water inside the car even though it had been shut constantly for a day or. 2.
    After a bit of advice I had found that a few pointers, I used some wd-40 in the latch,pressed dwn the switches under the bonnet and pressed the wires in the boot.
    After doing this I pressed the boot release and it made the usual opening noise,so I reattached the solenoid to the chassis and it worked,the warning had gone off the dash too...success!!! Then when I tried again after that it wasn't working so I'm back to square one, I am a little unsure where the problem lies now as the latch doesn't seem to move very freely but I'm unsure if the solenoid is working either,even though the warning is off now and the latch is shut unless I open from the inside manually. Any help with how to proceed would be much appreciated and if someone can diagnose this it would be most welcome, I am looking to fix this myself ideally and soon if possible.PLEASE HELP!!!!
    Many thanks...
  2. Re: Boot latch problems,please help!!
    nottinghamshire
    i have had the problem before but mine was just ceased because of the water, i did what you did and un ceased everything and mine was alright, what about the wiring in the boot sometimes wires can break where the boot shuts, if the wires are alright try the switch mech where the latch is maybe thats faulty, im sure water has messed up a few of these mechs in the golf section before??
  3. Re: Boot latch problems,please help!!
    Jan 2012
    Coding Something
    The hinge rubber boot isnt a well known issue on the 8P's tbh, water in the boot latch connector causes corrosion & thus doesnt work properly, so check all connectors for green corrosion & scratch them clean, clean out any wet areas.
  1. Question Boot latch opens on its own.
    By jonesrd1 in forum Golf Plus
    Last Post: 31-12-2013, 05:15 PM
  2. boot latch
    By strof in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2011, 07:44 PM
  3. Teething problems: smelly air con and boot latch issues
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-06-2011, 10:49 PM
  4. a8: Boot Latch Mechanism
    By flightliner in forum Body Work, Body Styling and Body Kits
    Last Post: 14-09-2010, 05:24 PM
  5. Avant boot latch
    By jetset in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 10:43 PM
