Thread: Headlight Washers...how do they work?
Results 1 to 8 of 8
  1. Headlight Washers...how do they work?
    Sep 2011
    Melksham, Wiltshire, UK
    It appears that I have headlight washers on the Superb...two chrome covers under each, which appear as if they should move.
    I've had a read through the manual but its not clear how these operate....is it me or are there some weird translations to English in the handbook?
    It goes on about 1st or 5th pull of the stalk to activate the washers. Eh?
    Is there a simple way to check that I have indeed got them?
    Have tried activating with headlights on, high beam on, pulling the lever, pushing it away...still no washers.
    Anyone care to enlighten me? Cheers.
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  2. Re: Headlight Washers...how do they work???
    46 Post(s)
    usual scenario is dipped/main beam on and pull the stalk towards you as normal to operate the washers .. maybe hold it for 2 or 3 seconds and see what happens.
    some models came with the cutouts for washers but never had them fitted.
  3. Re: Headlight Washers...how do they work???
    Sep 2011
    Hi Chris, I tried the logical route a la VAG design, but no joy. I am trying to figure out a definitive answer as to whether they are fitted or not, or just not working!
    Can you pull out the headlight washer jets like you can on the A3/Golf?
  4. Re: Headlight Washers...how do they work???
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    My MK6 Golf headlight washers only operate on every 5th activation of the windsreen wiper washer stalk.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Headlight Washers...how do they work???
    Sep 2011
    Quote Originally Posted by vwcabriolet1971 View Post
    Thanks for this...can you explain a little more how this actually works? Do you mean you have to pull the wiper switch towards you five times before the washers work?
    It seems a bizarre way to do this as my Golf Mk4, you just needed the headlights on main beam and pull the wash/wipe stalk towards you to activate the headlight washers..why change it, it works!
  6. Re: Headlight Washers...how do they work???
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Yes it means you have to pull the wiper switch arm 5 times before they work . I would guess that this is designed to conserve the washer fluid. You only have to pull the arm lever for a very brief period each time to count as 1 operation so its quite quick to operate the headlight wash .
  7. Re: Headlight Washers...how do they work???
    Sep 2011
    Tried it five times and more with headlights switched to main and full beams......no joy. Probably don't have them fitted then!
  8. Re: Headlight Washers...how do they work???
    Jul 2011
    Kilmarnock, Ayrshire, Scotland
    Do you have xenon headlights as you must have headlight washers when you have xenon headlights. If you don't have xenon headlights then I don't think that you would add headlight washers when the car was built as it would be a waste of money.
    2008 A4 B8 Avant 143 2.0 TDI & 2014 Skoda Superb Comb 4x4 170CR 2.0 TDI DSG
  1. Question Headlight washers
    By macman1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-10-2011, 09:20 PM
  2. Headlight Washers?
    By sneil2 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-02-2010, 07:50 PM
  3. Headlight Washers
    By malaroo978 in forum VCDS - Help Requests
    Last Post: 02-06-2009, 07:10 PM
  4. Headlight Washers
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-10-2008, 12:11 PM
  5. Headlight Washers?
    By RobDob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-09-2007, 12:46 AM
