Thread: coolant leaking after turbo changed
Results 1 to 10 of 10
  1. coolant leaking after turbo changed
    Jun 2012
    Leicester
    hi all,
    i have a 2009 MK6 Golf 1.4 TSI SE 122PS Manual.
    In Jan 2011 the turbo went and I got it replaced under warranty. A little while after the replacement (roughly mar/apr) I noticed a wet patch where I park my car on the driveway. I looked into and it was the coolant leaking (photos attached are from a few days ago). I've taken it to vw twice I think (middle of last year may/june), they've done pressure tests and looked around and they said there is nothing leaking. I left it at that. But it didn't leak that much or as often. couple of months after that it started leaking again (july/aug) that's when I found out about some liquid that can be poured into the coolant that will seal leaks. This helped for a few months. We're now around oct/nov and it's started to leak again. Few days ago I took the car to a local vw specialist in Peterborough and they found that some of the water pipes around the car engine was not sealed properly from a prior job this was the cause of the leaks. They've reseated the pipes and pressure tested and gave the car back to me yesterday saying it's all fixed. I have noticed this morning that it's still leaking little bit - but this may be from an over flow tray (if there is such a thing) so I've decided to give it a few days and continue my normal commutes to see what happens
    (1) I want to know if the replacing the turbo has any impact on coolant leak?
    (2) if a yes to number 1, is still VW responsibility to fix the problem, surely there is some warranty on the turbo replacement
    (3) Any other suggestions how to fix this issue?
    Kind Regards
    PS the car is out of warranty now.
  2. Re: coolant leaking after turbo changed
    nottinghamshire
    they must have disturbed something whilst fitting the turbo
    if it wasnt leaking before i would keep taking it back untill they sort it
    am i right in thinking your turbo is water cooled seen as its a petrol
    personally i wouldn't have used that stuff
  3. Re: coolant leaking after turbo changed
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    If you had the turbo replaced under warranty in 2011 and now you've noticed a leak since then its a bit long in time considering you took it back a few months after to have this leak investigated but they found nothing.
    Those pics don't really show anything apart from you have a leak that drips on the floor. You have two options now its out of warranty. Investigate where this leak is coming from if its an hose or joint then get the parts and fix it yourself. Or you take it back to the dealer and say its still leaking and get them to fix it but you will be charged.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: coolant leaking after turbo changed
    nottinghamshire
    I would take it back to the independent who did it last and get them to sort it, you obviously paid for the work you had done so take it straight back and tell them its still leaking
    is it deff coolant leaking, do you need to top up the water in the expansion cap
    plus the color of the leaking fluid looks brown and seen as its only just been repaired i would expect the color to be much cleaner?
    it will only overflow if you have filled it up too much
    ive had water dripping before sometimes it can come from the air con rad or sometimes ive seen it dripping after ive topped up the washer bottle
  5. Re: coolant leaking after turbo changed
    UK Ex-pat now in Australia
    Check around the coolant pump area as these are quite common for leaks - it is driven by the aux belt towards the rear of the engine. You will need to look from underneath whilst pressure testing and look for drip trails down the engine cover.
    Had MKV GTI, Now Ford Falcon
  6. Re: coolant leaking after turbo changed
    Sep 2009
    12 Post(s)
    Quote Originally Posted by FLENG2008 View Post
    VW antifreeze is brown/orange thats the colour of mine.
  7. Re: coolant leaking after turbo changed
    Sep 2008
    mostly in the garage
    Quote Originally Posted by ssaini View Post
    clearly it's not all fixed so you should take it back to the indy.......
  8. Re: coolant leaking after turbo changed
    nottinghamshire
    Quote Originally Posted by Keithuk View Post
    never seen brown before, mine is bright pink and i know its used to be green some years back
  9. Re: coolant leaking after turbo changed
    Aug 2009
    oxford
    If I remember correctly I read somewhere that the turbo on these cars is water cooled, so it is quite possible that either the pipes to the turbo or the turbo it's self has a small leak. The only way to check is to clean the area thoroughly, run the engine until fully up to temp then check the underside for drips. Very difficult unless you have a ramp.
    Golf mk6 GT TSI 160 3 door Black with convenience pack
  10. Re: coolant leaking after turbo changed
    Turbo is mounted at the front and is easily visible with the cover off.
    Red is the turbo.
    Green is the general area where the water pump is fitted.
    Looking at the pics you uploaded - it is coolant and it is in the area where the water pump is.
  1. Leaking coolant?!?
    By AudiTsport99 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-07-2010, 07:52 PM
  2. Replies: 0
    Last Post: 07-04-2009, 10:43 PM
  3. coolant leaking!
    By audi-nutz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2008, 06:32 PM
  4. Leaking Coolant
    By timsmith in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-01-2008, 09:14 AM
  5. Leaking coolant!!
    By nakhonian in forum Vento - 1994 - 1998
    Last Post: 30-12-2007, 01:16 PM
