I've had to change the low beam light bulbs on my Passat 53 model (1.9 TDI) and after changing both of them i find that beam is directed straight at the ground and I can't adjust it.
Someone said I had put the bulbs in the wrong way round, but I don't know how I could have done that?
One thing I did do was on the passenger side light bulb. It had an extra metal thing on top of the black plastic bit and I had to take the metal bit off then remove the bulb as it was really tight. I then put the metal bit and bulb back on the black plastic bit.
Any help would be much appreciated.
Thanks in advance
