Thread: Registration lights access?
Results 1 to 10 of 15
  1. Registration lights access?
    Oct 2010
    Rochester Kent
    Afternoon all
    Im waiting to fit a load resistor to the registration lights wiring to prevent the error code on the dash due to an LED upgrade. Any ideas where to locate the wiring as the description for the product installation is very brief an is a generic guide...
    Regards
  2. Re: Registration lights access?
    Jan 2012
    Coding Something
    In the bootlid.
  3. Re: Registration lights access?
    Oct 2010
    Rochester Kent
    I presume this is the panel where the 2 Allen bolts are where the handles are to pull the boot down?
    Regards
  4. Re: Registration lights access?
    Jan 2012
    Coding Something
    Lift the bootlid, remove the plastic trim covering this which can be a bugger by itself, which gives you full access to wiring from behind, that would be best place to fit any resistor pack, so its got more air to disperse heat build up.
  5. Re: Registration lights access?
    46 Post(s)
    Tip for releasing the spring clips .. give the top corners a good tug, you can then see where the rest of the pesky little things are and where you need to tug again.
    I never bothered with a long screwdriver, I just pulled it at an angle (I never broke the trim thankfully!) and they released.
  6. Re: Registration lights access?
    Oct 2010
    Rochester Kent
    I take it these spring clips Chris are to do with the plastic trim that NHN mentioned? Or Is this inside? The description you fellas have given are completely different to the installation instructions - fingers crossed it all makes sense when I get on with it.
  7. Re: Registration lights access?
    46 Post(s)
    Those spring clips are holding the boot trim on to the bootlid itself.
    Hold on .. just reread the thread, I know on a Sportback there are two little flaps either side near the handle on the inside, these prise off and reveal (I assume) the reversing and brake lights?
    I know they're there, but cant remember what the let you get to.
  8. Re: Registration lights access?
    Oct 2010
    Rochester Kent
    Okay so i have very little time to attack this in the evenings after work due to light constraints. I have re read the replies and i still cannot understand where the location of the number plate harness is? I have taken 2 pictures, the second picture i have taken off the 2 allen bolts to try and remove this lid, but it doesnt seem to unattach, i think its moulded in - i couldnt get it off.
    are any of these the places you were referring to in your replies?
    Regards
  9. Re: Registration lights access?
    46 Post(s)
    On the sportback there are two little flaps on the inner bootlid - shown below pic 1
    When these are prised off it reveals some wiring (pic 2) which I can only assume is the reverse, indicator and fog connectors.
    You didn't state whether you have a SB or 3 door but for 3 door I would guess you would need to remove the cluster itself as it doesn't integrate into the bootlid.
  10. Re: Registration lights access?
    Oct 2010
    Rochester Kent
    I have a 3 door Chris... An no like you say I don't have one of them sections in my boot. But I doubt they'd have the registration lights in this cluster would they?
  1. New registration.....
    By Rosscow in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-05-2013, 08:35 PM
  2. Replies: 1
    Last Post: 29-03-2011, 03:07 PM
  3. Please Help How do I access the rear lights?
    By TimS996 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2010, 11:16 PM
  4. Please Help Registration & boot lights
    By warby in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2009, 11:08 AM
  5. cannot get access to my side lights!
    By jayz_jayz in forum Golf MK4 - 1999 - 2004
    Last Post: 03-03-2008, 07:40 PM
