Thread: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
  1. 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Jan 2013
    Lincolnshire
    Hi, I'm really hoping somebody can help me / give some good advice. I'm not very mechanical minded in anyway, so please explain in laymen terms.
    My A3 currently has 140,000 on the clock. It was previously a company lease car, I bought it with 100k on the clock.
    I had a turbo replaced at 120k, then had the new injectors done via Audi recall at around 125k. I've had numerous problems with the DPF so I drive it hard around 3,000 revs to get it warmed up and eventually sorts it. It STILL has the same DPF fitted as when manufactured.
    The turbo blew again! I sent the turbo to AET Turbos (they seem to have good reviews) and they mention it was down to carbon build up, the exact words was "defiantly an engine problem" and advised to check the sump for oil quality.
    Has anybody had any similar problems? Could the DPF be the root of the problem?
    Many thanks
  2. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Jan 2012
    Coding Something
    If I was you, I'd consider a dpf removal & map to suit & fit another turbo, dpf would be expensive to replace.
  3. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Jan 2013
    Lincolnshire
    Just a quick update: They got the sump off today and found a small amount of gloopy carbonated oil but I've been told nothing major.
    I've had a quote from a garage of around £370 to have the DPF removed and ECU DPF Delete -does this sound about right?
  4. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    nottinghamshire
    you should change the oil feed pipe and renew the oil and filter when changing the turbo
  5. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Jan 2012
    Coding Something
    Seems a fair price for dpf removal etc.
  6. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Feb 2010
    Cambridge UK
    Doesn't new MOT requirement say that original emissions control equipment must remain on the car?
    eg:
    http://www.honestjohn.co.uk/askhj/an...-fail-the-mot-
  7. Re: 2007 A3 2.0 TDI 170 - Turbo failed AGAIN after 20k
    Jan 2012
    Coding Something
    Thats uncanny as there have been allot of dpf removal discussions on another forum I frequent & I can see this being a problem come mot time & also thought the same.
  1. 2007 A4 avant 2.0 Tdi 170 issues
    By deeempee in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2011, 08:51 PM
  2. Question 2007 A4 170 50k = Blown Turbo
    By ScottieA4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-07-2011, 12:32 PM
  3. Please Help 2007 A3 tdi 170 flat spot/misfire when cold
    By DirtyDieselLee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-09-2010, 09:15 PM
  4. Please Help Passat TDI 170 SEL 2007
    By LEE scaff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2008, 01:52 PM
  5. Vw Passat Tdi 170 Sel 2007
    Last Post: 05-09-2008, 06:01 AM
