Thread: Allroad 2.5tdi 2004 temperature guage
Results 1 to 8 of 8
  1. Allroad 2.5tdi 2004 temperature guage
    Dec 2012
    Doncaster England
    Hi everyone,
    I have a 54 reg Allroad 2.5tdi which I bought last March, so far its been fantastic with no problem, however over the last few weeks the temperature guage has been up and down. It used to run at 90, no matter how hot or cold the outside temp was, but at the moment its up and down. It never gets past 90 but sometimes doesn't register at all. I have checked the coolant levels and it all seems fine, I haven't needed to top it up at all.
    I'm hoping its something straight forward such as the temp sender, but any help would be great.
    Also can anyone tell me the location of the temp sender so I can check it, i've had a look but can't see it.
    Thanks in advance,
    Ben
  2. Re: Allroad 2.5tdi 2004 temperature guage
    Ayrshire, Scotland
    18 Post(s)
    the temp sender is right on top of engine, under the engine cover, green colour near front LH/center of engine,
    if guage is always low rising near to 90 but never gets there, I would think thermostat but if jumping around check this temp sensor, easy and cheap to replace, thermostat not so easy!!
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad 2.5tdi 2004 temperature guage
    Jun 2008
    Lichfield, Staffordshire
    I agree with BPAndy, most likely to be sender but check the viscous fan is not running at idle, I had both faults ...
  4. Re: Allroad 2.5tdi 2004 temperature guage
    Jan 2013
    Merthyr tydfil
    i just had same fault, changed sender first, took 5 mins, but no joy, use a news paper rolled up to stop viscous fan when engine cold, if u cant stop very possible thats broke. unfortunately for me it was thermostat, cost me £516. changed all belts tensioners same time.
  5. Re: Allroad 2.5tdi 2004 temperature guage
    Jun 2008
    I have some cardboard stuffed between the two radiators now with a gap down one side. The temperature gets almost middle of the gauge now. My viscous fan is stuffed.
  6. Re: Allroad 2.5tdi 2004 temperature guage
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by Golf tdi Hal View Post
    Can someone clarify? I thought the viscous fan ALWAYS ran even on idle (albeit lower rpm) as its driven by aux belt and its clutch mechanism. Did you mean the ELECTRIC fan?
  7. Re: Allroad 2.5tdi 2004 temperature guage
    Mar 2008
    High Wycombe
    The viscous fan will run, but won't speed up as much with the engine (the viscous drive slips). The rolled up newspaper (real me use their fingers!) should stop it when cold, otherwise the viscous coupling is siezed.
    If it's getting hot with the cardboard, then it's likely that it's the thermostat that is failing.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: Allroad 2.5tdi 2004 temperature guage
    Did you change the pump whilst the front was off. ?? Did you use a genuine Audi stat and all parts. Regards Peter
  1. Outside temperature guage
    By pauldonjuan in forum Golf MK4 - 1999 - 2004
    Last Post: 07-12-2010, 03:29 PM
  2. Engine Temperature Guage
    By dufferum in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2009, 03:55 PM
  3. Temperature guage!
    By Rogg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2009, 09:10 PM
  4. Temperature Guage
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 05:17 PM
  5. temperature guage
    By onefifty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2007, 07:28 PM
