Thread: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 79
  1. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #51
    Sep 2011
    Lurking over a keyboard ...
    Are your referencing to throttle valve body adaptation? AFAIK on A6 4F you just replace valve and no need to adapt, IIRC even VAG service guide have no recommendation on this but will double check...
    I've just got hold of an EGR cooler for £25... so now only need some intake manifolds and some good weather to crack on ....
    Quote Originally Posted by stretch o1 View Post
    by the way nice write ups gup fair play
    Thank you ...
  2. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #52
    May 2012
    dublin,ireland
    yea gup the electric throttle body the cogs where sheered off in mine replaced with a new one from gsf but car is hunting abit at idle i thought it needed to be aligned but i am not able to access it through vcds probably just on the petrol version it need tba,
    i seen in one of your posts you where thinking of getting a remap when i was having few issues with my own a chap connected up his autoboss to try sort few things i think he updated something and now i have a code (P0698 - 001 - Too Low - Intermittent, 17082 - Sensor Reference Voltage C) and coil light flashes only when im stopped in traffic ect no loss of power cant trace it, it has me stumped
  3. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #53
    Sep 2011
    Exact same thing happened mine.. very common issue...
    I hope this not come across bad... start a thread, we will all chip in... if we carry on in this thread it will be out of context for the thread title...
    Regards
    G
  4. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #54
    Sep 2011
    The used cooler arrived today for studying ...
    From some of the markings on the screws the EGR cooler & cooling unit may not have been ever separated since factory fitting...
    As it has 2005 year stamp will be interesting to see when EGR cooler & cooling unit separated how blocked it is...
  5. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #55
    May 2012
    dublin,ireland
    not at all gup ya bad <REMOVED!> HA HA.
    yeh i know the throttle issue good quality audi part alright i wasn't going into all that ,just wasn't sure if it needed tba to be done
    yea ive started a thread on it but no body loves me drop in any input welcome.
    if i sort it ill put up result head wrecker when people never finish post because they sorted it out not leaving any info for us poor sods .
    Ps gup you should put all your old parts in a box a big box at that, and send it to audi asking them how much they pay designers to make these parts guaranteed to fail
    because there geniuses
    Last edited by Guest 2; 03-03-2013 at 10:45 PM. Reason: Please read the rules, don't swear.
  6. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #56
    Sep 2011
    Hi ya mate ...
    After reading your post I checked your profile for started thread as couldn't see one in the C6 section...
    Your thread is this one Link:- little help on fault codes
    It can be a little quiet in that section... will look at your VCDS log tomorrow and if there is anything I can share I will mate ...
    You may get someone possibly see this link and go over there as well...
    Again not being unhelpful just a little selfish so I can be with some people I need to be with ...
    ATB
    G
  7. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #57
    Sep 2011
    As it was a nice day and Peachy the Peach A6 has been behaving I thought why not examine the EGR cooler which I'd bought from ebay (used)...
    This is from a 2005 V6 no idea on mileage will try to ask ebay seller... those bolts are M6 which fit snugly in the holes (15 a side)...
    Very little blockage I inserted a cable tie and could feel it bend round but too short to protrude out... the sooty powder removes very easily to show shiny metal below... the bolts were very easy to open between cooler & flap unit none were seized, just a little resistance at first then AOK...
    Still no idea when or if I will remove and clean my own one... but IMO you would know if you had a blocked EGR cooler via the MVB 03 module 01... you can force EGR always through cooler by just unplugging elec.harness to the EGR cooling flap solenoid and observe MVB 03, EGR valve will still open... Link:- audi 3.0tdi engine measurement blocks
    When I was doing glow plug on cyl.6 I was able to photograph the other banjo bolt on the coolant pipe... Please ref this post Link:- Post 46
  8. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #58
    Sep 2011
    Due to weather not really got that far with cleaning intake manifold top/bottom (x2) ... I also feel the coking is not only due to EGR gas/injectors but could also be exaggerated by how the crankcase ventilation system vents into charge air system... Link:- Oil residue on turbo face and/or output charge air pipe ...
    Haven't been able to find cheap used swirl manifolds ... the pair that I missed out on in post 23, which sold for £60 on ebay where probably the cheapest used I've seen so far ...
    Has anyone done the EGR valve/cooler removal and got any experience share?
  9. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #59
    Leicestershire
    After reading this thread and what a fantastic resource of info. My question was why had the subject of egr delete not come up?
    Is it possible?
    I know alot of other vag groups do this with great success.
    Audi A6 C6/4F 3.0 V6 TDI Quattro S-line - BMK
  10. Re: Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
    #60
    Sep 2011
    My EGR/Mass air is out of spec again ...
    This has been the best capture of event ever ... after 5-6 sec you will see a swing down to 777RPM then regular up/down of 777RPM-819RPM...
    EGR valve is being requested to open note the 20%, closed is 90%+...
    The video has been edited to the event... engine had been driven to get a little warm so to take the glow plug equation out...
    i) After switching on the ignition, the Glow Plugs Q10 – Q15 are switched on via the Automatic Glow Time Control Module J179 by the ECM at a temperature of less than 20°C.
    ii) Post-start glowing stops when engine coolant temperature reaches 35°C.
    So the saga continues ...
    Quote Originally Posted by techfreak View Post
    Is it possible?
    IIRC I saw a 3.0 TDi thread of EGR delete but before I do anything like I really wanna clean upper/lower manifolds....
  1. Manifold cleaning & common rail fuel system - help needed
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-03-2016, 08:53 PM
  2. EGR and intake manifold cleaning 3.0 V6 TDI
    By Leoflavio in forum Phaeton
    Last Post: 12-10-2010, 09:08 AM
  3. AFN intercooler & egr cleaning
    By killie.john67 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-05-2009, 11:51 AM
  4. How To WIRE UP AN AMP & SUB to an Audi Concert system.
    By the blitz in forum In Car Entertainment
    Last Post: 12-10-2008, 03:08 AM
  5. Question EGR System for TDI's - Keeping intake system clean
    By Audichap in forum Leon
    Last Post: 12-10-2008, 12:19 AM
