Thread: a3 sportback
  1. a3 sportback
    Mar 2007
    10 Post(s)
    hi i am considering buying an audi a3 sportback 2.0 tdi could anyone please tell me what year of car would get me away from the oil pump issues on these engines ie when did audi finally solve this issue. thanks in advance
  2. Re: a3 sportback
    Aug 2012
    Chester
    You should buy a 2009-onwards model as the 2.0 tdi was changed to a common rail unit which i believe are far more reliable than the older pd models.
    2008 Audi R8 4.2 V8
    2010 VW Golf GT 2.0 TDI 140
    Ordered: 2014 VW Golf GTD Coming March 2014
  3. a3 sportback
    46 Post(s)
    Don't forget about the über reliable 1.9 TDi - makes a good little car if its remapped and you won't be plagued with faulty injectors, oil pump's etc.
  4. Re: a3 sportback
    Jan 2012
    Coding Something
    Oil pump issues on the A3, dont know about that mate, A4's had issues with the pickup/balancer, so afaik you'll be ok, but the newer the better I'd say, 140 is pokey on the CR engines & no dpf afaik, 170 is dpf & earlier ones have had injector recalls which have been a nightmare for some.
  5. Re: a3 sportback
    Mar 2007
    10 Post(s)
    Quote Originally Posted by NHN View Post
    thats interesting so the oil pump issues on the 2.0tdi a4 and a6 as not affected the a3
  6. Re: a3 sportback
    Jan 2012
    Coding Something
    I havnt heard anything about the A3 on this particular issue, the A4 I read almost everyday, but like I said go for facelift 140 CR as earlier 140's had few issues & the earlier 170's people didnt like the dpf issues & injector recalls.
  7. Re: a3 sportback
    Feb 2010
    Cambridge UK
    Oil pump issue for the PD engine is when it's longitudinally mounted (ie A4 etc.). Transverse mounted engines (ie A3) don't have the weak point.
    As mentioned DPF is a common annoyance for all PD engines with them unless you do long runs - can't remember when they came in but my 55 reg doesn't have one so no problems for me there.
    The 170ps PD engine has a known problem with injectors - finally subject to recall though so this should be fixed/fixable for free.
    ABS ECU sensor is another weakness of most of the PD engines (and several other manufacturers), I've no idea if the CR engines have the same thing, but I'd go for one if possible due to the reduced emissions and smoothness (if you do have a DPF then the fewer the emissions the better.)
  1. A1 Sportback?
    By kamza in forum A1
    Last Post: 13-03-2012, 10:25 AM
  2. My New A3 Sportback
    By chiefwiggumpi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-09-2009, 02:08 PM
  3. A5 Sportback
    By onemanparty in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 06-09-2009, 08:41 PM
  4. S3 Sportback
    By onemanparty in forum Audi A3 - Archive Topics
    Last Post: 17-12-2008, 02:13 PM
  5. A5 and S5 Sportback
    By prolfe in forum Chat - Anything with wheels
    Last Post: 03-08-2008, 12:27 AM
