Hi All,
i have just upgraded the RCD 310 DAB to an RCD 510 DAB in my 2012 Golf MK6. After fitting I have noticed that the volume is very low in comparison to the old unit. After a bit of browsing around, I think it may be to do with the coding of the unit and if an external amp is fitted such as the Dynaudio system.
My car does not have any additional audio equipment, just the standard 8 speaker system. If possible, would someone with the same setup be able to list the coding options on VCDS?
Kind Regards
