Thread: Driver's door central locking doesn't work
Results 1 to 10 of 19
  1. Driver's door central locking doesn't work
    Jan 2013
    Northern Ireland
    Just got my first Audi yesterday - an '02 A4 1.9 TDI (130). One of the niggly issues I need to fix is the driver's door not working with the central locking (either from the remote or the central locking switch inside the car). All the other doors lock from the remote and the central locking switch. The drivers door and all the other doors lock when you turn the key in the door. It's the same situation with unlocking the door.
    I know this is a common problem and I done a search before posting this, but I couldn't find any threads with the info I needed. The previous owner told me that the wiring loom to the drivers door was replaced before, as was the controller for the electric window in the drivers door. The central locking was apparently working fine after this was all done and the issue with the driver's door locking only appeared recently.
    What I need to know is: Where is the first place to check the wires for breaks etc and how do I access the wiring inside the door? Is there anything else worth trying? I can't imagine that a blown fuse or anything would cause JUST the drivers door not to lock/unlock, but I guess it's worth a try.
    Any help would be greatly appreciated and if anyone knows of an existing thread that has the info I need, feel free to post a link to this thread, rather than repeating the information.
    Thanks in advance.
  2. Re: Driver's door central locking doesn't work
    Dec 2012
    poole
    i just had my door apart today because of broken wires in the rubber boot between the door and the body of the car. the rubber boot comes off easily and you can pull it back towards the door and check the wires, i found 3 broken. to repair them i took the door card off and removed the speaker, then you can unclip the wiring loom and pull them through to repair the damaged.
    hope this helps
  3. Re: Driver's door central locking doesn't work
    Jan 2013
    Leeds
    Do all the lights on teh door light up correctly? Does the windo work? I had this issue and nothing worked - turned out to be the ground cable in the rubber boot in the door.
    Chas
  4. Driver's door central locking doesn't work
    Jan 2013
    Northern Ireland
    @ Quattro Fan - Are there instructions anywhere online on how to take the door card off and access the wiring behind it?
    Everything else works on the drivers door - window controls (for both front windows), mirror controls etc. it's just the lock on the drivers door that's causing the issue.
  5. Re: Driver's door central locking doesn't work
    Jan 2013
    Leeds
    Quote Originally Posted by Big Dogg View Post
    To take off the door card is easy. Pop the cover off under the doorle and remove the screws. Remove the screws from the bottom of the door, and pop the trim (aluminium in my car) and there are screws under there. Then the card is on poppers. Just pop it offf and you in the door.
    Chas
  6. Re: Driver's door central locking doesn't work
    Dec 2012
    poole
    ther is a video on youtube of a guy in the US replacing a window regulator, search for AUDI A4 WINDOW REGULATOR, the guy is doing the job on the passenger door of a B6 A4. there you can see exactly how the door card comes off.
  7. Re: Driver's door central locking doesn't work
    Dec 2012
    poole
    also if you just google audi a4 door card removal, and door wiring plug there are a few threads with pictures on other forums. try this one.
    DIY: B6 A4 Window Regulator & Motor Replacement
  8. Driver's door central locking doesn't work
    Jan 2013
    Northern Ireland
    Happy days. I had found one for a B7, but couldn't find any for the B6, so this is useful. Hopefully it's dry after work this evening so I can try to get it fixed.
  9. Re: Driver's door central locking doesn't work
    Dec 2012
    poole
    good luck man, only took me 1.5hrs to take it apart fix it, put it all back together. just dont forget to reconnect the door handle cable, as i did, most anoying. and leave the window up as it makes it easier to get to the wiring behind the speaker.
  10. Re: Driver's door central locking doesn't work
    Jan 2013
    Leeds
    When i did mine i needed some new plastic poppers too - i have never mamanged to get them off without at least one snapping on me!
  1. Driver's door not working with central locking
    By Big Dogg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2013, 02:25 PM
  2. Important central locking does not work
    By malikmali in forum Chat - Anything with wheels
    Last Post: 22-05-2009, 09:41 AM
  3. Please Help Driver's door central locking not working
    By eytch in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2009, 11:31 PM
  4. Central locking leak in driver's door - 95 A4
    By Olimur in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2009, 04:24 PM
  5. Please Help Central locking and driver's window
    By VW.Tastic in forum Polo - Derby - Lupo - Fox
    Last Post: 12-06-2008, 05:13 PM
