Thread: Poor radio reception
  1. Poor radio reception
    May 2008
    Hi all,
    I have fitted a sony headunit in my mk4 golf as i wanted the mp3 usability and the radio reception goes somewhere between bad and totally unlistenable, the reception wasnt terrible on the original gamma unit but even so wasnt exactly stunning. Would a signal amplifier help here does anyone know or is there something else going on ?, thanks in advance.
    John
  2. Re: Poor radio reception
    Mar 2008
    Leiderdorp, Netherlands
    I suggest that you check the antenna, I had a similar problem with my old MK4 which turned out to be a crack at the base of the antenna.
  3. Re: Poor radio reception
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Did you use the correct wiring connectors to adapt the loom? I believe that the mk4 golf has a signal amplifier built into the aerial base, that has a feed from the back of the original radio, so you do need to use the correct connectors.
  4. Re: Poor radio reception
    Aug 2011
    Meath
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2011, 11:14 PM
  2. Poor FM/AM radio reception
    By Herbiv4 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-04-2009, 09:16 PM
  3. poor radio reception on aftermarket radio
    By pukrik3@pukrik3 in forum New Member Introductions
    Last Post: 23-07-2008, 09:21 AM
  4. Poor Radio Reception
    By jaydeee in forum Golf MK3 - 1993 - 1999
    Last Post: 17-05-2008, 08:32 AM
