Hi guys, i did a VCDS scan on my fathers 2000 golf tdi today as his airbag light is staying on and his M.O.T is due soon. Below are the results.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 0F AIRBAG VW5 01 0004
Coding: 12358
Shop #: WSC 00028
VCID: 3561EB640F6BFDB0C2A
3 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
28-00 - Short to Plus
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
01280 - Airbag; Passenger Side; Disabled
35-00 - -
I am able to clear the crash sensor faults but the Airbag Passenger Side will not clear as soon as you wipe it instantly returns. I removed the seats and checked the airbag connections which were clean with no corrosion what so ever, i also did the same with the crash sensors under the carpet and they were also corrosion free. Once the ignition has been cycled the other 2 faults return. One other thing i have tried to re activate the passenger airbag using my VCDS but it will not allow, i enter 0 and save it but the value returns to 1 straight away. Does this indicate that the airbag module in the footwell needs replacing? any help appreciated.
