Thread: S3 headlights fit to A3
Results 1 to 10 of 16
  1. S3 headlights fit to A3
    Sep 2012
    carlisle
    Hello all,
    Is it possible to fit S3 DRL bi-xenon lights to an A3 S-LINE 56 plate 8P model?
    thanks
  2. Re: S3 headlights fit to A3
    Jan 2012
    Coding Something
    Depends which year lights, if they're 06-08 then yes, facelift led drl's no, not wiothout a front end conversion, but needs wiring, coding & specific modules to be able to do this, I do it fairly often & there are hurdles you need to be aware of, plus need the right tools to do so, namely vcds.
  3. Re: S3 headlights fit to A3
    Sep 2012
    carlisle
    what cost could i be looking at by fitting S3 lights to my A3 then?
  4. Re: S3 headlights fit to A3
    Jan 2012
    Coding Something
    Which year version headlights did you want to fit?
  5. Re: S3 headlights fit to A3
    Sep 2012
    carlisle
    id be looking to fit bi-xenons to the car, so id assume that could be from any 06-08 S3 5 door. As your previous post states the DRL version on the models 09 onwards will require alot of mods.
  6. Re: S3 headlights fit to A3
    Jan 2012
    Coding Something
    Well that would of depended on your other thread discussion of front end etc, so couldnt be sure which.
    Also if you wanted to fit levelling systems & headlight washers required by mot.
  7. Re: S3 headlights fit to A3
    Apr 2014
    Birmingham, UK
    Hi, I have an 8P its a 61 reg but was built in feb 2012 which means its a nightmare for me to figure out if its pre or post facelift! I am looking to buy these LEDs: Original Hella Audi A3 S3 8P Facelift Xenon Headlights LED Day Model 2009- | eBay to it. I have read about fitting washers and levelling systems.. I just want to know if these lights will be compatible with my model car and also roughly how much would I be looking at to get them fitted? Trying to weigh up if its going to be worth me buying Audi lights or simply going down the Dayline route
    Thanks in advance!
    H
  8. Re: S3 headlights fit to A3
    46 Post(s)
    Facelift started in MY2009.
    Should be compatible but you need the other parts is headlamp washers and self beam levellers too. Kufatec sell these so look at their website.
  9. Re: S3 headlights fit to A3
    Jan 2012
    Coding Something
    Quote Originally Posted by MrHSingh View Post
    Thanks in advance!
    H
    They will fit yes, but make sure they're rhd, even if they state they are, check part numbers 100% before buying.
    We supply/fit all these systems if interested & on your doorstep possibly
    Apr 2014
    Birmingham, UK
    nice one.. looks like its gonna be a mini project then.. will have to start putting the pennies aside for a new front bumper and washers and levellers.. will all be worth it in the end
    nice one bud, I don't know any audi fitters off hand so will defo keep you in mind for the fitting once I've got my hands on all the parts needed
  1. Need help: Good priced vag com bodyshop to fit new headlights
    By JohnBoyJunior in forum Golf MK5 - 2004 - 2009
    Last Post: 12-05-2012, 11:29 PM
  2. Rs4 headlights, will they fit my s line?
    By P Smiddy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-02-2010, 06:49 AM
  3. Possible to fit LED strip to Xenon headlights?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-02-2010, 03:38 PM
  4. How To Fit 99-01 headlights on a 95 A4
    By Bruce-1980 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-01-2009, 11:08 AM
