Thread: Help with Audi dealer diagnostic codes
  1. Help with Audi dealer diagnostic codes
    Jan 2013
    Australia
    I have just had my Q7 TDI checked for issues surrounding the immobilization issue I'm having and need to confirm if they are correct in their assessment as I don't beleive its a full ECU and ignition coil replacement.
    Keys have been checked and no issue.
    The error codes are as follows, which they believe lead to part J518 (which is a major expense $$$):
    Any suggestions greatly appreciated.
    Error messages:
    Errors: Infrastructure.Vehicle.ODS8003E
    Text: ODS8003E Infrastructure.Vehicle (EcuCom): The operation on the control unit with the control address 0x00 was faulty. Error message: <Ungueltiges Argument uebergeben>
    Errors: Infrastructure.Vehicle.ODS8011E
    Text: ODS8011E Infrastructure.Vehicle (EcuCom): Control unit with control address 0x42 is not installed or does not respond.
    Text: ODS8011E Infrastructure.Vehicle (EcuCom): Control unit with control address 0x52 is not installed or does not respond.
    Text: ODS8011E Infrastructure.Vehicle (EcuCom): Control unit with control address 0x62 is not installed or does not respond.
    Text: ODS8011E Infrastructure.Vehicle (EcuCom): Control unit with control address 0x72 is not installed or does not respond.
    Text: ODS8011E Infrastructure.Vehicle (EcuCom): Control unit with control address 0x05 is not installed or does not respond.
  2. Re: Help with Audi dealer diagnostic codes
    Mar 2013
    Harrogate
    how old in your q7? What are the symptoms of the fault.
    Regards
    adam
    Passatcc 1.8t Reflex Silver 2008 - VCDS USB-Hex-CAN
  3. Re: Help with Audi dealer diagnostic codes
    Jan 2013
    Australia
    Quote Originally Posted by Vcds-harrogate View Post
    Regards
    adam
    Hi Adam, the car was 2008 model bought new. It had a few issues along the way like the fan to push the a/c dying and an electrical issue with the tail lights which never really went away. Basically once we identified it was the ECU then there was no way to override the computer system which immobilized the car. Power came into the car but no radio, fans, lights etc. dash lights came on only. Had to be towed to the dealer in the end as other mechanics had no experience in replacing the parts. Cost AUD$2800 from the s t e a l e r s !! Sold it 4 months ago now and have finished with Audi after having owed 4 different models.
  1. Please help diagnostic codes, what do they mean??
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-04-2011, 07:47 PM
  2. Question diagnostic codes for injectors
    By RichardJWilson in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2010, 05:33 PM
  3. Replies: 3
    Last Post: 06-06-2009, 01:40 PM
  4. 95 Passat diagnostic codes
    By randombob1190 in forum Early Passat Forum - Pre 97
    Last Post: 13-04-2009, 07:53 AM
  5. caravelle automatic diagnostic codes?
    By Russellbar01 in forum Chat - Completely Off Topic
    Last Post: 20-01-2007, 02:22 AM
