Thread: radio problem
Results 1 to 10 of 10
  1. radio problem
    Jul 2007
    i have a 2001 1.9 tdi and when i purchased the car the radio only worked om fm and not on medium wave and long wave .I replaced the radio with a new one and i still have the same problem.Any ideas as i am baffled
  2. Re: radio problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Sounds like the aerial base in the roof is at fault
  3. Re: radio problem
    Jul 2007
    Is it a bad job to change as i guess the roof lining has to come off
  4. Re: radio problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Just drop it down at the back to access the nut that fastens it.Be carefull not to bend the roof lining
  5. Re: radio problem
    Jul 2007
    cheers i will try and get one
  6. Re: radio problem
    May 2007
    Bath, Wilts
    Quote Originally Posted by jrw View Post
    Same year & type. Presume you have a Double Din Symphony ? If so read on, my Symphony didn't work much on FM and not at all on LW/MW, plus CD player keeps saying error 1 on all CDs!
    First thing to check is your aerial, but don't take the roof lining off, you get to the bottom of the aerial via the rear roof lights. Pop them out, but there's not much to see/check.
    Second, look behind LHS rear wheel arch and check connections to a small unit, called the diversity unit, which if it's the same as mine, sits on top of the bass unit. It collects signals from the roof aerial and small aerials on both sides of the rear window, behind the trim. Problem here is that the Diversity unit connects them all together and connects to the radio - however, as mine was kaput, Audi want £100+ for a new one!!! I doubt they will let you borrow one to check just in case either !! I've had no luck with On-line breakers either !! Hen's teeth 2nd hand it seems.
    Your possible solution would be to replace Audi aerial and run it direct to your radio of choice or perhaps the the Symphony will now work - a new aerial fitted was £40 inc vat.
    My solution - replace Audi roof aerial for an amplified DAB aerial (looks exactely the same as norma Audi) and feed aerial direct to my DAB radiop with CD player and MP3 capable. Problem now is no-one makes a double Din Facia kit for 01/02 Audi A3's with double Din !! (OK you can cut down an A6 version, but it's not the same !!). Still on the look out tho'!!!!
    If you have the double din, don't be conned into thinking "aaahhh" I could go Sat Nav & DVD. The early A3 double din is a bit unique !!!
    Hope that helps?
    Trev McM
  7. Re: radio problem
    Jul 2007
    Mine was a concert system but i have had a look above the bass unit and there is nothing there. Thanks for the info though
  8. Re: radio problem
    May 2007
    knee deep in clunge
    14 Post(s)
    just a roof aerial for you with in built amplifier
  9. Re: radio problem
    Jul 2007
    does the a3 use the heated rear window as an aerial for mw and long wave
  10. Re: radio problem
    Aug 2007
    Elgin
    I've also got a 2001 1.9TDi just had it 3 weeks and the previous owner had replaced the radio with a pioneer. I'm struggling to get a good signal- sometimes it won't even pick one up. Turns out that you have to put a booster in the back of the radio before connecting the aerial, mine was fitted but the connection on the Audi Aerial lead doesn't fit the booster well and keeps disconecting- even when I covered it in electricians tape. Will need to find another solution.
    Good Luck
  1. Help with Audi radio problem?
    By Mr Tea in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-12-2008, 02:01 PM
  2. Concert radio problem.
    By Barnz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2007, 08:21 PM
  3. RADIO PROBLEM PLEASE HELP!!!
    By tonypeters in forum Chat - Completely Off Topic
    Last Post: 30-10-2006, 04:04 PM
  4. 98 Passat Radio CD CCM problem?
    By limawhiskey in forum Passat - Archive Topics
    Last Post: 14-10-2006, 11:18 PM
  5. 98 A4 Radio problem.
    By glenniosaurus in forum Archive posts
    Last Post: 29-06-2006, 05:05 PM
