Thread: 57 plate Audi A6 3.0tdi Le Mans
Results 1 to 10 of 10
  1. Talking 57 plate Audi A6 3.0tdi Le Mans
    Dec 2012
    Edinburgh
    Brand new member looking for help advice on the above vehicle. Having test driven it I'm Looking to buy it over the next few days. When checking that all the electrics were working I couldn't get my IPhone 4S to pair with the Bluetooth. When going in to the Bluetooth settings it doesn't give the option to find new phone. It has the MMI with sat nav although to what spec I don't know. Also, in the arm rest there looks like part of a cradle for a phone. Can anyone help with advice on the Bluetooth and the cradle in the arm rest? Also, how easy is it to fit/upgrade the stereo to accept iPod either by plugging in or by Bluetooth?
    Many Thanks
    Paul
  2. Re: 57 plate Audi A6 3.0tdi Le Mans
    Jan 2013
    Perth, UK
    Hello,
    Did you ever find out the answer to this? I'm in exactly the same position, test drove the same car and had the same issue with the 4s!
  3. Re: 57 plate Audi A6 3.0tdi Le Mans
    46 Post(s)
    To pair a phone and to make sure Bt is fitted, press TEL then SETUP and you'll see an option for searching.
    If the central screen is colour, you will have DVD nav (MMI High) but if its Red you will have MMI Basic+ but I think you have High.
  4. Re: 57 plate Audi A6 3.0tdi Le Mans
    Dec 2012
    Edinburgh
    Hi mate,
    yes I did, found the answer on the forum after some digging. Basically if you sit in the drivers seat all you have to do is hold the phone very close to the centre console beside your left knee. Go through the bluetooth settings on your phone to find new devices and it should come up with the audi unit. Insert the PIN number from the mmi display and it should connect. Apparently the phone needs to be right beside the unit the first time it's paired! It's working perfectly for me!!
    Hope it works for u!!
    All the best
    Webby
  5. Re: 57 plate Audi A6 3.0tdi Le Mans
    46 Post(s)
    Doesnt need to be anywhere near the centre console as the bt module is below the passenger seat lol
  6. Re: 57 plate Audi A6 3.0tdi Le Mans
    Dec 2012
    Edinburgh
    Yep, I had read that Chris. Don't know if its just cause I was holding it lower down then but phone wouldn't find the unit until I done it!
    Regards
    Webby
  7. Re: 57 plate Audi A6 3.0tdi Le Mans
    46 Post(s)
    Least it connected!
  8. Re: 57 plate Audi A6 3.0tdi Le Mans
    Dec 2012
    Edinburgh
    Just as well, I had bought it by then! Lol
    Found viewing other threads on the Forum very helpful.
    Regards
    Webby
  9. Re: 57 plate Audi A6 3.0tdi Le Mans
    Feb 2013
    Measham Derbyshire
    I found with most bluetooth systems is it seems to work better when you search for devices from the phone rather than asking the car to do it.
  10. Re: 57 plate Audi A6 3.0tdi Le Mans
    46 Post(s)
    The iPhone doesn't like it done that way - well mine anyway.
    Is best searching from the car IMO.
  1. Replies: 10
    Last Post: 17-04-2013, 10:06 PM
  2. A6 3.0TDI Le Mans - 07 - Suspension knocking...?
    By markorbilly in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-04-2012, 09:30 AM
  3. New 2010 A6 Le mans 2.0 TDI (170) or 3.0TDI?
    By V5 Man in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-04-2010, 03:57 PM
  4. Please Help Tyres for 55 plate A4 S-Line 2.0TDi
    By rosedani in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-02-2009, 02:54 PM
