Thread: Electrical gremlins / where are the ecu's on a vw touran?
  1. Electrical gremlins / where are the ecu's on a vw touran?
    Mar 2014
    midlands
    Picked up an 05 plate tdi touran off a neighbour. It's been sitting for about 9 months due to turbo problems.
    I'm getting some electrical gremlins so thinking damp has got to the various ecus so would like to take them out and dry them off.
    Does anyone know where the ones that control the steering wheel and the abs are located?
    There's a few issues:
    ABS/ESP or whatever it's called light is on once the engine starts but goes out after a very short distance (no faults with brakes on computer)
    The steering wheel light comes stays on as orange/yellow and then does the same as the above (only a recent thing)
    The front wipers only occasionally work (no pattern to this) but the rear one always works. They also dont 'jump' when the engine goes on or off
    code read it with vagcom and it gave the following:
    005784 - Please Check DTC Memory of Steering Wheel Electronics
    P1698 - 001 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 250
    Reset counter: 255
    Mileage: 254374 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:14:38
    Freeze Frame:
    RPM: 2520 /min
    Speed: 91.0 km/h
    Load: 80.8 %
    Voltage: 14.29 V
    Bin. Bits: 11001000
    Bin. Bits: 00000000
    (no units): 0.0
    and
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000005754942
    Coding: 00890F2100040F0000120C000000000000087B075C
    Shop #: WSC 01324 785 00200
    VCID: 2A5BD3FC855D6C7111F-807F
    Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 110506 020 0501
    Coding: 00038805
    Shop #: WSC 01324
    1 Fault Found:
    01049 - Supply Voltage Term 50
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 6.70 V
    OFF
    ON
    ON
    OFF
    OFF
    Does anyone have any advice?
    Thanks,
    steve
  2. Re: Electrical gremlins / where are the ecu's on a vw touran?
    May 2007
    17 Post(s)
    Quote Originally Posted by flat4fanatic View Post
    What was the trouble code in the steering wheel electronics? Maybe that will give you a clue what the trouble is.
    The steering electronics ECM is under the steering cowlings and the ABS ECM is attached to the ABS pump module near the N/S bulkhead in the engine bay
    Jim.
  3. Re: Electrical gremlins / where are the ecu's on a vw touran?
    Mar 2014
    midlands
    Hi Jim, thanks for the reply.
    the fault was possibly the cruise control:
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenksäulenmodul 035 0070
    Coding: 0000042
    VCID: 74E70D8417196A817B3-8021
    1 Fault Found:
    00895 - Cruise Control Switch (E45)
    014 - Defective - Intermittent
    By Rastapopolos in forum Alhambra
    Last Post: 22-06-2014, 11:58 PM
  2. electrical gremlins
    By Alaska in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2013, 01:31 PM
  3. Please Help Electrical Gremlins!
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-09-2011, 04:53 PM
  4. Electrical gremlins
    By mboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2011, 08:40 AM
  5. Electrical gremlins
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-04-2008, 11:06 PM
