Thread: Engine pinking
Results 1 to 10 of 16
  1. Engine pinking
    Dec 2007
    Belfast
    Hi All.
    I have posted before on this though can't find the post.
    My engine is making a rattly metallic type of noise under acceleration in fourth and fith gears.
    I am using as high an octane fuel as I can get.
    I am now thinking that if I used a quality oil would this help my problem ?
    At the minute I am using Carlube semi sinthetic as it was cheap.
    Maybe if I used something like Castrol ?
    Marko.
  2. Re: Engine pinking
    7 Post(s)
    Quick, give Mystic Meg a ring, bet she knows what engine you have.
  3. Re: Engine pinking
    Dec 2007
    Belfast
    Engine details as follows.
    2001 1.6s 16v ( AZD ) 80.000mls
  4. Re: Engine pinking
    Pembrokeshire
    22 Post(s)
    nowt wrong with carlube. code read ?
  5. Re: Engine pinking
    Dec 2007
    Belfast
    Haven't had the car plugged in. It would have to be an independant and I dont know what I should get them to read.
  6. Re: Engine pinking
    Pembrokeshire
    22 Post(s)
    they will know what to do, but basically scan for engine fault codes. you could have a knock sensor gone down. any pinking and the ecu will retard the timing. in fact , to optimise performance it keeps the timing roughly at the point where its just not pinking. old cars with distributors did this with bob weights pretty well, but an ecu does it more complicated. if your problem is pinking, then it does sound like something is wrong electronically.
  7. Re: Engine pinking
    Dec 2007
    Belfast
    Thanks.
    Will pay a visit to the mechanic in the new year.
  8. Re: Engine pinking
    46 Post(s)
    Question Engine pinking !!!! ... Your original thread.
    If you need a scan, I will be in Belfast next Saturday all going well.
  9. Re: Engine pinking
    Aug 2011
    Meath
    I thought it was the knock sensor last time
  10. Re: Engine pinking
    Oct 2012
    uk - york
    HI, you could of had a doggy fill up - bad fuel can cause all this - if not engine timing to advanced.
    2004 VW Touran - Engine AZV 2.0 litre TDI
  1. Question Engine pinking !!
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 18-11-2012, 09:16 PM
  2. Please Help pinking cabby ADZ engine code
    By paul targett in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2008, 06:29 PM
  3. Please Help ABK engine pinking / pre-ignition
    By audi80mk4 in forum 100 - 200 - Turbo - 100 S4
    Last Post: 22-09-2008, 07:30 PM
  4. Please Help ABK engine pinking / pre-ignition
    By audi80mk4 in forum 80 - 90
    Last Post: 30-08-2008, 02:23 PM
  5. 3.2 Engine Pinking
    By Hillsy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2008, 09:27 AM
