Thread: Jerky Acceleration
Results 1 to 10 of 17
  1. Jerky Acceleration
    Dec 2012
    Boston
    Audi A3 '56 2.0 TDI 170bhp
    Had this car for couple of years with no problems. Last 3 months the car has decided to have an increasingly more jerky acceleration.
    The engine itself makes no more or different noise to normal, and has been serviced to the handbook.
    Revving is smooth, slow acceleration is smooth but anything more aggressive has an acceleration that has a pauses as it revs threw. It is most noticeable between 2500 and 5000 revs and cold. When up to temperature 90degrees still jerks but not quite noticeable.
    Has anyone got any pointers ?
  2. Re: Jerky Acceleration
    Nov 2009
    46 Post(s)
    Have you had your injectors checked if they are part of the recall?
    ring audi customer service on 0800 699888
    Open Monday to Friday 8am to 6pm, Saturday 8:30am to 4pm
  3. Re: Jerky Acceleration
    Dec 2012
    Boston
    Hi Chris, thanks for the idea, these were replaced during the recall.
  4. Re: Jerky Acceleration
    Nov 2009
    46 Post(s)
    Ah I see - always worth trying every possibility
    Any untoward lights on on the dashboard?
  5. Re: Jerky Acceleration
    Dec 2012
    Boston
    We have had only 2 since owning car
    Not long after recall we had DPF warning and was told this was because the cars journeys are usually less than 10 miles. Used a DPF fuel additive and did the longer run at constant 60 and all well, no returning light
    Last month we had eps/abs which were told related to worn rear pads which were replaced during service couple weeks ago but the Missus has just told me this has flickered on a couple of times since but not stayed on.
  6. Re: Jerky Acceleration
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Just a thought, but when you are accelerating hard, do you get the Traction lamp flashing? I was thinking it could be related to wheel-spin and the ecu is backing the throttle off.
    Alan.
    VW T6 150 DSG Camper £££
  7. Re: Jerky Acceleration
    Dec 2012
    Boston
    Thanks for idea, but no other lights come on but I dok know what you mean.
  8. Re: Jerky Acceleration
    Aug 2012
    Newquay, Cornwall
    Does it feel like the feeling you get when you let the clutch up too quickly or is it more like a judder?
  9. Re: Jerky Acceleration
    Dec 2012
    Boston
    Hi Mikey
    Neither really, it's hard to describe but it is like the car is pulling normally as it revs through but then a pause before it goes again. It can occasionally pause for a more noticeable length of time but always goes again.
    It vertainly isn't shaking or juddering the car.
  10. Re: Jerky Acceleration
    Jan 2012
    Coding Something
    1st of all, I dont recall rear pads having any wear sensors so doubt its this for esp light up, 2nd when were injectors swapped out as there have been major issues with the new injectors for loads of people, has it been since these were changed & 3rd fuel filter been changed yet?
    Crasher is a good guy to go see, but not sure how close he is to you.
  1. jerky acceleration
    By cwrtcoed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2010, 02:51 PM
  2. Please Help Jerky Acceleration
    By Mattio in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-05-2010, 05:49 PM
  3. No Acceleration and jerky when it does accelerate!
    By michelle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-12-2009, 07:58 PM
  4. Audi 1.6 engine jerky on acceleration
    By thomaslab in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 08:10 PM
  5. Jerky Acceleration problem
    By djronw3 in forum Passat - Archive Topics
    Last Post: 14-12-2006, 01:06 AM
