Thread: Brake Pad Warning Light On, How Far Can I Keep Going?
  1. Brake Pad Warning Light On, How Far Can I Keep Going?
    Nov 2009
    Arundel
    Had the car serviced recently and was told there was 20% left on the pads. The warning light (and loud sound!) comes on now, but I'm in the back of beyond in Scotland. Realistically how far can I travel in this condition?....i wanted to get some fancy Redstuff pads fitted but am thinking I may have to make do with something cheaper just to get me home!...
    Golf Hatchback 2012 1.6 tdi CAYC
  2. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    Nov 2012
    Australia, Melbourne
    I'd drive carefully if i were you. In other words- i'd attempt to drive back home. DO NOT brake hard, try to slow down using gears. Should do the trick.
    ... someone with more experience should answer... i know... ill shut up ...
  3. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    glasgow
    35 Post(s)
    Back of beyond in Bonnie Scotland ? Your in Gods country man !! Anyway look in the wheel and you will see the pad. It all depends how you drive your car in how long you have left. If you get to Inverness , Stirling , Glasgow , Edinburgh then change them if your worried.
  4. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    Aug 2011
    Meath
    Metal on metal will ruin your disks and metal on metal makes a poor brake especially in an emergency. My advice don't drive it and get a set of pads.
  5. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by as400 View Post
    Had the car serviced recently and was told there was 20% left on the pads. The warning light (and loud sound!) comes on now...
    Warning lamp in dash panel insert will light up when wear limit 3 to 4mm is reached... depends on your PR codes for brake setup...
    You can see some tech data here... Link:- Brakes
    To get the brake PR codes see your car data sticker in wheel well/service log book...
  6. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    Jun 2007
    1000 miles would not be an issue. However, check the fluid level in the hydraulic reservior. Regards Peter
  7. Re: Brake Pad Warning Light On, How Far Can I Keep Going?
    Nov 2009
    Arundel
    Quote Originally Posted by Peter D View Post
    That will be handy, I'll take it steady and get some nice Redstuff popped on.
  1. Brake pad warning light
    By mangroa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-11-2012, 02:44 PM
  2. Brake pad warning light
    By dan.taylor.1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2011, 07:04 PM
  3. brake pad warning light
    By geord1egooner in forum Polo - Derby - Lupo - Fox
    Last Post: 31-03-2009, 09:11 PM
  4. A4 Brake Pad Warning Light
    By brianboru in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-02-2009, 02:46 PM
  5. Brake Pad Warning Light
    By darkskies in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-11-2007, 11:26 PM
