Thread: A6 bulb monitor
Results 1 to 10 of 10
  1. A6 bulb monitor
    ireland
    2008 a6 2.0 tdi saloon bulb monitor intermittent warning , happens after 5 to 10 minutes of driving , single or multi bulb failure at r/h rear , brake light , tail light, indicator , new bulbs fitted , contacts cleaned , connection to rear light panel ok, only happens on o/s/r
  2. Re: A6 bulb monitor
    46 Post(s)
    very common problem - leaking clusters
    get a new one bulb holder from audi
    1 1 0
  3. Re: A6 bulb monitor
    ireland
    Is the bulb holder therefore going to open circuit as a result of moisture in rear cluster , so does the rear light Assy have to be replaced also if it is letting in moisture ?
  4. Re: A6 bulb monitor
    46 Post(s)
    theres a big thread in this very section A6 Rear light cluster ( 07) includes fixes, replacement bits etc ..
    1 1 0
  5. Re: A6 bulb monitor
    Sep 2011
    Lurking over a keyboard ...
    Looking at your first post Kenmurray you've done most stuff, but IIRC in the thread that Chris highlight there is a earth point which people sort aswell... I think Brycie had this and done on his...
    1 1 0
  6. Re: A6 bulb monitor
    Mar 2008
    11 Post(s)
    Had the same here 2 months ago
    Right cluster kept going - one bulb after another in succession until only the brake light worked (LED so isolated from the others as it is not on the same holder)
    Cleaned, dried, worked for a day but then started playing up again
    Ended up replacing the bulb holder from Audi - only cost around £20 from memory. Ironically, I changed it in the rain as it was dark and I had a long motorway journey to do after picking the part up so I had to change there and then. 2 months on, it still works fine
    What I did do as I was removing the cluster was I ended up removing all the bulbs and replacing them for new/better ones. Same on the other side, just wish I changed the bulb holder on the other side too but nevermind!
    1 1 0
  7. Re: A6 bulb monitor
    ireland
    As chris pointed out in earlier post re A6 rear light cluster (07)
    I added another post there as it is relation to moisture in rear light ,
    Moisture in rear light also causes this issue ,
    this is more a safety issue than cosmetic issue,
    2008 a6 2.0 tdi saloon bulb monitor intermittent warning , happens after 5 to 10 minutes of driving , single or multi bulb failure warning at r/h rear , brake light , tail light, indicator , new bulbs fitted , contacts cleaned , connection to rear light panel ok, only happens on o/s/r
    More than likely condensation build up inside rear lens caused by heat generated on inside surface against outside cold surface , causing multiple bulb failure or breakdown of internal supply voltage to bulbs at bulb holder , will try drilling off inside of lens and moisture removal within next week , re clean contacts etc , repost ASAP
  8. Re: A6 bulb monitor
    Sep 2011
    Not just on this car but on others I have found that contacts which have a tendency to corrode smearing a bit of petroleum jelly (Vaseline) inhibits return of corrosion...
    I did this treatment on mine... issue never return...
    1 1 0
  9. Re: A6 bulb monitor
    ireland
    Rear light cluster male pin found with discoloured surface , cleaned up with nail file and applied contact cleanser , female side supplies negative earth to indicator , tail lights ect , through brown wire ,
  10. Re: A6 bulb monitor
    131 Post(s)
    1978 Post(s)
    Change the earth terminal for a gold plated one using either an AMP crimp terminal or a VAG repair wire 000 979 133 AB (£3) and 6R0 973 735 (£6) is the housing if it is melted. If pin in the bulb holder is clean, tin it with solder, these two steps will drastically reduce the resistance and so reduce heat generation under high load.
    1 1 0
  1. Bulb monitor problem?
    By juppy in forum Golf Plus
    Last Post: 22-02-2012, 08:24 PM
  2. Flip out monitor
    By Mattwarner1979 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-01-2011, 11:05 PM
  3. VI monitor
    By bez101 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 27-12-2009, 01:34 PM
  4. PS3 Monitor
    By mluton in forum Chat - Completely Off Topic
    Last Post: 27-03-2009, 01:46 PM
  5. Bulb Monitor do I need to reset it
    By MathewRB in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2009, 11:20 PM
