Thread: 98 polo 1.0 ltr starting and running probs
  1. 98 polo 1.0 ltr starting and running probs
    Feb 2012
    camelford cornwall
    hoping you guys might be able to help
    sometimes if i catch it right the car will start no probs but most of the time it just spins over then with full throttle it eventually starts, tried doing the throttle body reset by holding it down etc but doesnt work also as soon as i drive the revs increase to 2k and takes ages to return to idle
    also if i pump the brake a few times on idle the revs increase to around 1600-1800 then drop back down
    the cars only done 59k and had a full service not long ago inc plugs the double electrode ones
  2. Re: 98 polo 1.0 ltr starting and running probs
    Aug 2011
    Meath
    First of all check the timing. Check your crank sensor, knock sensor, temperature sensor and idle sensor. If you google them you will find information on how to check them with a multimeter
  3. Re: 98 polo 1.0 ltr starting and running probs
    Feb 2012
    camelford cornwall
    im putting my money on the coolant sensor, im getting one on thursday car runs fine apart from that and is surprisingly nippy for what it is do these cars suffer from the servo breaking down as its very low millage and vac pipes are fine ?
  4. Re: 98 polo 1.0 ltr starting and running probs
    Aug 2011
    Meath
    Theyre great little cars. Test the servo by pumping the pedal with the engine off. When it goes hard start the car with your foot pressing the brake, the pedal should drop 10-15 mil, if it doesn't suspect the servo
  5. Re: 98 polo 1.0 ltr starting and running probs
    Feb 2012
    camelford cornwall
    replaced the coolant sensor and all is hunky dory wouldnt think a £4:50 part would cause so many issues
  1. 1997 Polo 1.4 Cold / Damp starting and running problems
    By mungo_55 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-01-2011, 02:19 PM
  2. A4 starting/running probs
    By Oak UK in forum Audi A4 - Archive Topics
    Last Post: 12-01-2008, 05:41 PM
  3. n reg polo starting probs
    By sedgebank in forum Polo - Derby - Lupo - Fox
    Last Post: 05-01-2008, 06:54 PM
  4. polo diesel 96, starting probs when hot
    By lanius in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 11:15 PM
  5. Cold starting probs on Polo Diesel
    By billyboy in forum Polo - Derby - Lupo - Fox
    Last Post: 29-08-2006, 10:34 AM
