Thread: Grinding noise from rear when braking
  1. Grinding noise from rear when braking
    Aug 2012
    Essex
    Hello merry xmas to all . i have an 09 passat highline tdi dsg , when braking there is a grinding noice from rear wheels , had car since august 2012 was fully seviced in april . would be greatful for members input and ideas , there are no warning lights
  2. Re: Grinding noise from rear when braking
    UK Ex-pat now in Australia
    Although it may have been serviced in April, the pads may have been 60% worn then. The usage by yourself may have put the brakes close to metal.
    See about getting a free brake check somewhere - or a free EVC at VW.
    Had MKV GTI, Now Ford Falcon
  3. Re: Grinding noise from rear when braking
    Sep 2008
    SE London
    When did this noise start? Does the noise happen all the time under braking?
    Was this full service including change or check rear brake pads? If so, were the pads changed by main dealer?
    Does car pull to left or right when braking?
  4. Re: Grinding noise from rear when braking
    london/ UK
    Take the wheels off and check how much meat is left on he pads, they're down to metal if they grind only when braking...
  5. Re: Grinding noise from rear when braking
    Up North
    It's a long shot but I had a similar problem with the rear brakes of my my Golf two years ago. It turned out to be a stone trapped between the disc and the backplate. Pads looked fine and because the disc is smooth plus the stone was flat sided it took several days of frustration and noisy brakes to figure it out.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  6. Re: Grinding noise from rear when braking
    Aug 2012
    Essex
    Thanks one and all for taking the time to answer my problem . Had to fit new brake pads and renew discs £160 all in . now ok even if my wallet is not .
  1. Important Grinding noise coming from the rear brakes.
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-11-2011, 08:44 PM
  2. Please Help Grinding noise.... at 2-3k
    By eltoro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2010, 06:00 PM
  3. Question Grinding noise
    By GMAN6 in forum Polo - Derby - Lupo - Fox
    Last Post: 08-11-2009, 04:12 PM
  4. Question Grinding Noise From Rear
    By makinlove88 in forum Audi A3 - Archive Topics
    Last Post: 14-04-2009, 03:57 PM
  5. help grinding noise
    By klix11 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2008, 11:01 PM
