Thread: Rear wiper does not spray, water leaks out over rear driver side wheel. 08 Leon 1.6
  1. Rear wiper does not spray, water leaks out over rear driver side wheel. 08 Leon 1.6
    Sep 2008
    Swapped my aging Bora for a 08 Leon, and have noticed that when I try the rear washer, I get no fluid at the blade, checked outside, and there is a leak from above the wheel at the rear. No puddles inside. Anybody know if there is a connector there, and how to get to it if there is?
  2. Re: Rear wiper does not spray, water leaks out over rear driver side wheel. 08 Leon 1.6
    Jul 2007
    glasgow
    35 Post(s)
    Look to see how the trim comes off and have a look
  3. Re: Rear wiper does not spray, water leaks out over rear driver side wheel. 08 Leon 1.6
    Aug 2009
    hull
    Hi Torch_taylor
    Look in the boot , left hand side were the boot light remove the panel ( push the seat forward to get to a screw) the wash pipe work has a elbow joint which might have come apart (mine did ) , hope this help's
  4. Re: Rear wiper does not spray, water leaks out over rear driver side wheel. 08 Leon 1.6
    Jan 2013
    edinburgh
    these have a habit of doing this, there is a long thin copper or brass like pipe which your washer jet pushes into, tbh i cant remember if you have to take the motor out ,but basically the small pipe corrodes which in turn lets water come out the motor and into the boot floor, these are available on ebay priced around 10-20 quid. hope it helps
  1. Replies: 11
    Last Post: 20-05-2021, 09:21 PM
  2. Squeaking noise from Driver Side rear wheel
    By lifemoveon in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-09-2011, 09:20 PM
  3. Water in the driver side footwells.. front and rear
    By Boyleyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-07-2011, 01:56 PM
  4. Question wiper linkage and rear washer jet spray
    By JarvisTheCocker in forum Ibiza - Cordoba
    Last Post: 01-03-2009, 09:26 PM
