Thread: a6 oil sensor issue and airbag issue
Results 1 to 10 of 11
  1. a6 oil sensor issue and airbag issue
    Dec 2012
    wales
    hi my a6 has had a diagnostic and came back with the 562 sender for oil level sensor g266 open circuit/short circuit to positive sporadic..and also 562 sender for oil level sensorg266 implausible signal..
    also airbag issue is 1228 airbag cut off switch front passenger side e224 open circuit/short circuit to positive sporadic...and also airbag cut off switch front passenger side e224 defective sporadic...any help how i can sort this out the airbah light comes and goes and also the oil sensor light flashes on display..thanks in advance i also have random abs and traction light coming on then going away once i shut ignition off and reset it
  2. Re: a6 oil sensor issue and airbag issue
    134 Post(s)
    2022 Post(s)
    What is the cars year and engine code?
  3. Re: a6 oil sensor issue and airbag issue
    Dec 2012
    wales
    2001 51 plate 2.5 TDI TIPTRONIC quattro sport estate engine code AKE
  4. Re: a6 oil sensor issue and airbag issue
    134 Post(s)
    2022 Post(s)
    00562 Oil level/temperature sender-G266
    Open circuit/short to positive or Short to earth = Open circuit in wiring, short or blown fuse
    Implausible signal = Oil level/oil temperature sender -G266 defective
    Check fuse 5 in the dash side fuse box
    01228 Key switch. Switch off airbag, BTU -E224. Open circuit/Short to positive
    Open circuit = Fault finding according to current flow diagram
    Key switch -E224 defective = Replace key switch -E224
    Control unit for airbag -J234 defective = Replace control unit for airbag -J234
  5. Re: a6 oil sensor issue and airbag issue
    Jul 2011
    Norway
    If fuse nr. 5 is ok, the G266 sensor are known to go bad. Don't buy a aftermarket P.O.S, they will make your oiltemp gauge not working.
  6. Re: a6 oil sensor issue and airbag issue
    134 Post(s)
    2022 Post(s)
    True, all the aftermarket level sensors I have tried were rubbish.
  7. Re: a6 oil sensor issue and airbag issue
    Dec 2012
    wales
    is the sensor the one fitted to the bottom of the sump..any idea how much..also if i turn the keyoff for airbag would this cause the airbag issue to stop..also tonite ive notice sometimes the abs and traction light comes on while driving and goes off if i turn off engine and restart any ideas there ..thanks in advance
  8. Re: a6 oil sensor issue and airbag issue
    Jul 2011
    Norway
    Yepp, fitted to the bottom of the sump. Not a bad idea to replace it when you change oil. Prize? Dealer- way to much. Ebay used oem- 15-20 eur.
    About the other stuff it would probably be the best to scan for faultcodes ( VCDS)
  9. Re: a6 oil sensor issue and airbag issue
    Nov 2011
    Duns Scotland
    11 Post(s)
    Intermittent ABS & Traction lights on (at the same time) could be faulty Brake Light Switch (located under brake pedal in driver's footwell). Had this a year ago with my 2002 Allroad AKE 2.5TDI. Replacement secondhand cost £30 with 3 moth guarantee and still going string.
    BUT ..... Before replacing, a vcds scan should identify if this is your probem.
  10. Re: a6 oil sensor issue and airbag issue
    134 Post(s)
    2022 Post(s)
    But a new brake light switch genuine from Audi is about £10! W T F are you doing paying £30 for one?
  1. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  2. Airbag sensor passenger side issue (with pics)
    By Trickster138 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2011, 10:25 PM
  3. Please Help A4 Airbag light issue
    By boredinbris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2010, 01:09 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. 2.8 30V Quattro - Airbag issue
    By bp083503 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2009, 03:35 PM
