Thread: BNS 5.0 SAT NAV CD Player and Radio Safety Code entering Procedure ????
  1. BNS 5.0 SAT NAV CD Player and Radio Safety Code entering Procedure ????
    Jan 2009
    Can anyone help me ?
    I have an almost new BNS 5.0 Sat Nav Unit which I want to fit into my 2007 A3 , at present its fitted with a Concert II unit.
    Knowing that when I do the swap and power is restored to the BNS 5.0 Unit it will require its 4 digit Security code entering to get it to work again, does anyone know the procedure in order to enter a BNS 5.0 Sat Nav's security code .
    Presumably there is a button , or two that must be pressed in order to initiate the entering of the code sequence , any idea which button/buttons .
    Having initiated the code sequence, how is the 4 digit code entered into a BNS 5.0 ?
    And how is the completed 4 digit code confirmed (saved) ?
    And yes, I do have the code !
    I also have the Handbook for the BNS 5.0 , but Audi in its wisdom leaves this very important procedure out in its entirety, as it does from the Handbook of my existing fitted Concert II unit .
    Thanks in Advance
  2. BNS 5.0 SAT NAV CD Player and Radio Safety Code entering Procedure ????
    46 Post(s)
    It's simple to enter the code. When you plug it in all will be come clear.
    Entered the code on my RNS-E within 10 seconds.
    The code is stored within the unit and you only need to enter it once.
    Why did you go for a BNS? You would've been happier with a RNSE IMO.
  1. Entering Postcode on sat nav audi le mans 2010
    By oliverm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-09-2012, 09:39 AM
  2. Another SAT Nav question BNS 5.0
    By gogsboy in forum In Car Entertainment
    Last Post: 14-01-2010, 01:04 AM
  3. Entering Radio Code
    By Encorebill in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 12:45 PM
  4. Polo radio code procedure
    By billR in forum Polo - Derby - Lupo - Fox
    Last Post: 24-02-2008, 06:28 PM
  5. 1994 S4 - I need a procedure to reset radio with code
    By davidatley in forum 100 - 200 - Turbo - 100 S4
    Last Post: 25-01-2008, 11:03 AM
