Thread: engine mount TDI Avant
Results 1 to 10 of 13
  1. Re: engine mount TDI Avant
    Jan 2011
    derby UK
    Thanks. It just look odd. First I was under impression it is a mount that is broken.
    Anyway, B6 hydro engine mount can be replaced with rubber one from B5.
  2. Re: engine mount TDI Avant
    Aug 2011
    Meath
    Did you check the used mount has fluid in it? they leak and your engine will shake like a Fordson tractor
  3. Re: engine mount TDI Avant
    Jan 2011
    derby UK
    Dont know how you open it. I've got a small leak from intake air pipe which was dripping on it. Hence it looked oily. How would you check for it? Also, the sensor on site - can it be removed?
  4. Re: engine mount TDI Avant
    Aug 2011
    Meath
    The hydraulic fluid is red and leaves a red stain if you open it, its scrap
  5. Re: engine mount TDI Avant
    Jan 2011
    derby UK
    don't think there was any red trace around it. May be that it is all gone long time ago. I've had a code on and when idle at constant RPM engine did not look smooth. Now it looks better.
  6. Re: engine mount TDI Avant
    Jan 2011
    derby UK
    still have a clanging noise tho when I let car slip down the slope while in reverse and clutch depressed. If I try to engage the reverse then at the point when clutch starts catching there is one single clang noise. Checked the drive shaft yesterday on drivers side. Nothing obvious.
    May need to take it into garage
  1. golf tdi 150 snapped engine mount!
    By marcus037 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2015, 09:13 PM
  2. Lug for engine mount snapped off engine!!
    By Graywd in forum Golf MK4 - 1999 - 2004
    Last Post: 02-10-2012, 08:13 PM
  3. mk5 golf 2.0 tdi engine mount
    By teddy2k5 in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2011, 08:43 PM
  4. Golf GT TDI AJM engine Mount breakage
    By cardend in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2009, 10:02 AM
  5. engine Mount
    By twindecks in forum Alhambra
    Last Post: 12-03-2009, 12:45 AM
