Thread: Cam belt Change?
Results 1 to 10 of 14
  1. Cam belt Change?
    Oct 2012
    Solihull
    Hi, I drive an A4 B8 1.8t S Line 2008. Went to my local Audi dealer today (Birmingham Audi) and asked about when my cam belt needs to be changed. They said every 5 years. My car has nearly 80,000 Miles on it, which I thought would be the correct time to change the belt. Any ideas if this sound correct?
  2. Re: Cam belt Change?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I don't know if it's different with your model, but any car I owned would have had it's cambelt done before 80k miles. I would be booking it in asap.
    The Only Way Is A6!
  3. Cam belt Change?
    Dec 2012
    Birmingham, England
    I think my B7 was done as recommended at 60k miles.
  4. Cam belt Change?
    46 Post(s)
    I stick to 60k or 4 years whatever comes first
  5. Re: Cam belt Change?
    Jul 2008
    People used to recommend changing the water pump at the same time to save on labour costs. Is this still a sensible and cost-effective recommendation, and any idea how much this would additionally cost at dealer and inde?
  6. Cam belt Change?
    46 Post(s)
    Definitely get the water pump done too - your dealer should be able to tell you how much.
  7. Re: Cam belt Change?
    Oct 2012
    Solihull
    Thanks ladies and gents, I thought this sounded a bit odd, Im going to book it in today. Anybody got any ideas if they would give me a courtesy car being 18 Years old?
  8. Re: Cam belt Change?
    Scotland
    Historically the water pump was changed at the same time as timing belt because VAG, in their wisdom, ran both off the same belt. There were instances where workshops just changed the timing belt and later on the water pump would seize and strip the teeth off the reinforced rubber belt or snap the chain (depending on the engine) destroying a large part of the engine (and onwers wallet ).
    This was certainly true for the 2.6 V6 I had. I would have thought they'd have changed the design by now though.
    Peter
    2017 A4 B9 2.0 TFSi S-line S-tronic
    2009 A4 B8 2.0TDi SE Avant (written off by a van )
    2005 A4 B7 2.0TDi SE Avant (gone)
    2002 A4 B6 1.8T Sport Quattro Avant (gone)
    1995 A4 B5 2.6 Sport Quattro (gone)
  9. Re: Cam belt Change?
    Aug 2010
    London
    Quote Originally Posted by SattyA4 View Post
    I wouldn't expect a courtesy car to be honest. Their insurance usually says something about being only for those aged 25+ or something, which is daft when you consider that the poverty-spec box they'll probably give you has less power than what you've driven in with... Worth an ask anyway though!
  10. Re: Cam belt Change?
    Oct 2012
    Solihull
    Well finally getting the cam belt and water pump changed by Birmingham Audi for £529. They have said to me that I will receive a courtesy car, they said its usually like for like which is good, need something with 4 doors so a A1 would be useless. Im surprised they would allow an 19 year old to have a courtesy car to be honest.
  1. cam belt change
    By golfman2 in forum Golf MK6 - 2009 - 2013
    Last Post: 02-07-2015, 01:17 PM
  2. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  3. Cam belt change
    By rjt64 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2011, 12:36 PM
  4. Cam belt change
    By chesh2000 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-04-2009, 02:37 PM
  5. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
