Thread: Video: Replacing ignition starter switch
  1. Video: Replacing ignition starter switch
    Oct 2011
    Rastatt, Germany
    the video shows you how to diagnose and how to replace the ignition starter switch at a Passat 35i. For this repair the steering wheel, the lock and the reduction sleeve on the steering column has to be removed. Especially pulling the reduction sleeve might be a problem. The video gives you a step by step instruction for this repair:
    The video has a German soundtrack but English subtitles are available at YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the video frame.
    Enjoy it,
    Jürgen
  2. Re: Video: Replacing ignition starter switch
    Brynsadler South Wales
    A big thank you to Jurgen for posting these videos they really are extremely helpful but I did try this method this week to change my switch and couldn't find anything good enough for the puller to grip to so in the end I disconnected the steering column at the universal joint under the pedals ( just a 13mm nut and bolt) and pulled the column right out,I was the able to gain access to the stupid little Phillips screw by putting a slight bend into and old screwdriver,just thought I'd post this as an alternative way if you haven't got a puller.
  1. How To Video: Replacing the brake hose
    By Dr944S2 in forum Golf MK1 - 1974 -1984
    Last Post: 03-07-2012, 05:48 PM
  2. Please Help 12v at ignition switch but nothing at starter solenoid.........
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 01-11-2011, 01:46 PM
  3. Please Help Ignition Starter Switch
    By Rammer in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-09-2009, 06:31 PM
  4. Ignition switch/barrel and starter motor
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2008, 08:25 AM
  5. Ignition Switch does not engage Starter
    By massauto in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 09:36 AM
