Thread: How to adjust Windscreen Washer jets?
Results 1 to 8 of 8
  1. How to adjust Windscreen Washer jets?
    Uxbridge
    Does anybody know how to adjust the Windsreen washer nozzle ?. As my nearside is set far to low..........
    Or is this another Audi job as it needs special tool or hard work like changing a light bulb.
    A3 (8V) Saloon Sport 1.8T S-Tronic 2014 (MY2015)
    Leather, Heated Seats, Technology Pack, Xenon Light Pack, Interior Light Pack, Adaptive CC, Audi Parking Plus + park assist, Reversing Camera, Advance Key, Comfort Pack, Storage Pack, Folding door mirrors, Privacy Glass, 10-spoke Alloys, Tyre Pressure Loss Indicator, B&O Speaker System.
  2. Re: How to adjust Windscreen Washer jets?
    Apr 2012
    Aylesbury, Bucks
    There is indeed a special tool! Not much to it in reality, just a short stiff metal rod of the right diameter, with a handle. For home use needles are too brittle, and paperclips too flexible :-(
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  3. Re: How to adjust Windscreen Washer jets?
    Jul 2007
    glasgow
    35 Post(s)
    it used to be that a small sewing needle would fit in the nossle and then move the jet
  4. Re: How to adjust Windscreen Washer jets?
    46 Post(s)
    i use a fine sewing needle, works fine just dont press too hard into the jet.
  5. Re: How to adjust Windscreen Washer jets?
    Nov 2012
    North Somerset
    If it's like the Avant & I assume it is then you can do it by opening the bonnet and removing the nozzle housing the large black plastic bit, just prise it away. Be careful of the pipe and electrics for the heated nozzle. This give much better access but unfortunately adjusting the jet will be trial and error. As far as what to use I've used a needle but they can snap easily.
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  6. Re: How to adjust Windscreen Washer jets?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by ChA6dders View Post
    I think raflecther have the info concerning that... otherwise have check here Link:- Adjusting spray jets - Audi A6 and Audi allroad
  7. Re: How to adjust Windscreen Washer jets?
    Apr 2012
    Aylesbury, Bucks
    And today I tried to do it, because as "stock" the factory setting on the new jets is a bit low. I even got a tool off ebay to do it with. Huh! The adjusting "needle" is too fine, so there is too much slop when it's in the nozzle, and because the nozzles are hiding a couple of inches under the bonnet rim, the tool hits the bonnet before any movement of the jets! I'll have to a) find a better fitting bit of metal (a thick needle I guess) and b) use the chadders method of trial and error I think. Sunday should be dry enough to try again.
    Edit: Sorted through the whole of my wifes sewing box to find a needle that a) would fit but b) not go too far in. Then managed the drivers side with the bonnet shut, and the passenger side by opening the bonnets, using a mirror and the needle to adjust by feel (e.g. pure guesswork!). All jets now about 70% correct, and thats good enough for me - if I try any more they'll no docubt "jump" and I'll be decorating the scenery.
    Has shown me a few chips on the windscreen I should get attended to though.
  8. Re: How to adjust Windscreen Washer jets?
    Sep 2011
    When I adjusted rear I found placing masking tape at points guide suggest helped get aim right...
    Glad you suss it ... can be such a fiddly exercise...
  1. Windscreen Washer Jets...
    By srisport in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 23-05-2012, 03:08 AM
  2. Question Windscreen Washer Jets
    By mark27 in forum Bora - 1998 - 2005
    Last Post: 10-11-2010, 09:32 AM
  3. adjust washer jets?
    By sidlaw72 in forum Touran - Sharan - Caravelle
    Last Post: 13-01-2010, 09:36 PM
  4. Question Heated windscreen washer jets
    By johngilbert371 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-01-2009, 01:39 PM
  5. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
