Thread: Brake Creep / Soft Pedal After Pad Change
Results 1 to 10 of 17
  1. Brake Creep / Soft Pedal After Pad Change
    Mar 2009
    Hi all, pads were low so changed the backs first a few weeks ago, all good, then the fronts this weekend. I swapped them out as I have done many times, just eased the piston back into the calliper and put the new pads in etc. After doing this (forced a little fluid out of the master cylinder), I have a soft pedal that needs pumping once to get a pedal and then it creeps down if compressed. I suspected air but can't see how it could have got into the lines.
    After researching, it seems that I should have un-done the bleeder whilst pushing back the piston, but again, I haven't had an issue before. So I have bled the brakes, and quite a bit of air came out. However, I still have the soft pedal. I suspect there is still air in the lines, and am hoping that I haven't screwed the master cylinder....
    Any thoughts appreciated.
  2. Re: Brake Creep / Soft Pedal After Pad Change
    Dec 2009
    southampton uk
    How did you take fluid out of the m/ cylinder?I have usually remove any excess from the res
  3. Re: Brake Creep / Soft Pedal After Pad Change
    Mar 2009
    I didn't - I didn't notice and a bit spilled over the top - forced out of cap. Not too much so easy to wipe down the top of the MC.
  4. Brake Creep / Soft Pedal After Pad Change
    Dec 2012
    Birmingham, England
    That's the way I do it on all my cars, although with the cap removed so as not to over-pressurise.
  5. Re: Brake Creep / Soft Pedal After Pad Change
    Mar 2009
    Yes, I've not had this problem before - I can't see how air has got into the lines, and so am worried that the MC seals maybe damaged - maybe as I forced the piston back in this way?
  6. Brake Creep / Soft Pedal After Pad Change
    Dec 2012
    Birmingham, England
    If I'm honest, I have forgotten to remove the cap a few times in the past and not caused any problems.
    Can't be sure if the fluid was 100% full though, so there may have been some slack there.
    I don't understand where your air has come from either. Maybe a problem with the piston seals?
  7. Re: Brake Creep / Soft Pedal After Pad Change
    Dec 2012
    swansea
    is it diesel or petrol?
    When you say pedal creep. Do the pads bite and then if you keep the pedal pressed hard the pedal will creep slowly to the floor?
    I've never bothered to remove the cap and never had any issues before.
  8. Re: Brake Creep / Soft Pedal After Pad Change
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If this is the pedal having further travel/soft feel when driving, it would be best to bed the pads in then see if it improves. A slight lip on the discs will cause this `soft pedal` feel.
    Alan.
    VW T6 150 DSG Camper £££
  9. Brake Creep / Soft Pedal After Pad Change
    Dec 2012
    Birmingham, England
    Very good point Alan.
    Although OP noted his brakes bled a fair bit of air out after the work, so unless it was already in there it's a little strange.
  10. Re: Brake Creep / Soft Pedal After Pad Change
    Mar 2009
    This is a diesel 130 TDi on an 04.
  1. Question Brake pad change
    By jimmymci in forum A8 - S8 - V8
    Last Post: 31-08-2009, 11:12 PM
  2. brake pedal after pad change
    By adrianrobinson in forum Bora - 1998 - 2005
    Last Post: 25-04-2009, 10:56 AM
  3. Soft Brake Pedal
    By igbell in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2008, 07:06 PM
  4. Soft Brake Pedal
    By Dude15 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2008, 04:15 PM
  5. Brake Pad Change
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2007, 10:17 AM
