Thread: Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
Hybrid View
  1. Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
    Aug 2007
    Help, i have noticed that my 1993 Audi 80 1.9 TDi started juddering at low rpm's, then cutting out for a spit second under load, I then noticed that the pipe from the fuel filter (arrow pointing toward engine) to the fuel pump had bubbles in it.
    Is this the cause, if so, how the hell are they getting in there??
    I wondered whether the fuel filter seal is leaking, but no sign anywhere of diesel leaking.
    I have only just bought the car and it has been sat for a while.
    Any help would be great
    Peter
  2. Re: Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
    Aug 2007
    its the injector pump on its way out
    a temp fix is to stick a one way valve on the line
  3. Re: Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
    Aug 2007
    Hi and thanks for your help, but how will a one way valve stop air bubbles getting to the pump??
    the bubble are moving from filter toward the pump, no bubbles in the return pipe
  4. Re: Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
    Aug 2007
    sry, taught the air bubbles where coming from pump. check the bleed bolt on top of the filter is tight and also the filter is a tight fit.
  5. Re: Audi 80 TDi - Air Bubbles in the Fuel inlet pipe
    Aug 2007
    Okay, if it is niether of those where else could these damd bubbles come from?
    I'm hoping this is the cause of my judder / cut out
    Not the dreaded Audi shuffle !!
  1. wheres da audi a4 1.8 inlet air temp sensor?
    By filmonkz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-08-2008, 05:09 PM
  2. A6 1.9 Tdi Inlet Air Temp Sensor
    By mickyboy22 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-08-2007, 06:29 PM
  3. Air bubbles in fuel line ?
    By cbrpaul in forum Touran - Sharan - Caravelle
    Last Post: 01-07-2007, 01:23 PM
  4. inlet air temp sensor?
    By filmonkz in forum Audi A4 - Archive Topics
    Last Post: 20-03-2007, 07:59 PM
  5. inlet air temp sensor
    By jim80 in forum 80 - 90
    Last Post: 26-11-2006, 05:17 PM
