Thread: Petrol in diesel
Results 1 to 9 of 9
  1. Petrol in diesel
    Jan 2012
    driffield, uk
    Hi, I know the wrong fuel thing has been well covered but I'd be grateful for any advice. My wife (honest!!) put about 3.5 litres of petrol in our 2002 Passat 1.9 Tdi SE the other evening. The car was nearly empty. She then added about 30 litres of diesel. It ran fine the next day (doing a 50 mile round trip) until the evening when it suddenly refused to start. After about 10 minutes of trying it reluctantly spluttered into life and drove fine. This morning it started first time as usual but has had several episodes of been a bit reluctant. Apart from the starting issues it runs as normal. Will this issue resolve itself? Cheers
  2. Re: Petrol in diesel
    46 Post(s)
    id be changing the fuel filter for good measure
    welcome to vwaf
  3. Re: Petrol in diesel
    Pembrokeshire
    22 Post(s)
    as long as the starting issue is the petrol, then yes it will get better. i would get straight down to a pump and brim it with diesel though. 25 % max petrol is what vw told us when i worked for vw assist, so you are well within that limit. petrol doesn't ignite as well as diesel without something to light it, wheras diesel goes just with heat, hence why it has trouble starting.
  4. Re: Petrol in diesel
    Oct 2009
    Worthing
    Just keep topping the tank up every day for the next few hundred miles and you'll be fine Changing the fuel filter might be worth it as the petrol will rise above the diesel in the filter which might be your starting issue but as above if it starts....
  5. Re: Petrol in diesel
    london/ UK
    I would not worry about it at all, just add a little 2 stroke oil to the tank and you should be good ! I always add a few liters of petrol when going to eastern europe in winter, the cold weather makes the fuel gel...petrol or kerosene stops it from getting too thick !
  6. Re: Petrol in diesel
    Jan 2012
    driffield, uk
    Thanks for taking time to reply. Not worried now. Cheers
  7. Re: Petrol in diesel
    Dec 2007
    Did this to mine some 50k ago and did no harm whatsoever, if anything it ran a little smoother with a touch of petrol.
  8. Re: Petrol in diesel
    Pembrokeshire
    22 Post(s)
    petrol is a cheaper alternative to injector cleaners.
  9. Re: Petrol in diesel
    Jul 2011
    Near Uxbridge
    Quote Originally Posted by adamss24 View Post
    Just use their diesel.....they winterize it by increasing the cetane levels....won't gel till around -26C. :thumbup:
    Sent from my phone...
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  1. Petrol in a Diesel
    By Clach1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-10-2012, 10:17 PM
  2. Petrol or diesel?
    By slee02 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-08-2012, 11:06 PM
  3. Petrol v Diesel
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-07-2010, 09:06 PM
  4. 2.5 Petrol to 2.4 Diesel
    By chalkmyster in forum The Classic VW's
    Last Post: 16-05-2010, 10:59 AM
  5. Petrol in a diesel
    By twindecks in forum Alhambra
    Last Post: 21-04-2010, 05:34 PM
