Thread: Aftermarket LED Tail light problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Aftermarket LED Tail light problems
    Sep 2012
    Kent
    Hi, i have just bought a 2005 A6 saloon and have bought some aftermarket LED taillights for it. I fitted them yesterday and I'm having problems getting them to work properly.All of the lights work apart from the brake lights.The high level brake light still works bit the ones in the clusters don't. I obviously get the brake light bulb out warning on the dash but also get a warning that the n/s/r light is out,although that is working. i was told when I bought them that they were just plug and play,so are these a faulty set or do I need to get the car coded for them to work? If the car needs to be coded can it be done by Vagcom or do I have to take it to Audi? I have been trawling the internet all morning but don't seem to be able to find a definitive answer!
    Thanks in advance
  2. Re: Aftermarket LED Tail light problems
    Nov 2010
    Watford
    Can't say for sure as these are after market and may be different but if you fit original LED rear lights you do have to change the coding (adaptation) using VCDS to make them work.
    You add this to the adaptation for standard rear lights (from Ross Tech Wiki) +0131072 = Highline (LED Rear Lights)
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  3. Aftermarket LED Tail light problems
    46 Post(s)
    You need to enable the Highline coding in vcds for them to work even with aftermarket units
  4. Re: Aftermarket LED Tail light problems
    Sep 2012
    Kent
    Ok,thanks for the replies guys. Looks like I'm going to have to find someone around here that has vcds. It's really annoying as when I bought them I was assured that they were plug and play!
  5. Re: Aftermarket LED Tail light problems
    46 Post(s)
    Have a look in my signature at the map - if you need anyone PM'd let me know and I will bring their attention to this thread.
    Take plug 'n' play with a pinch of salt!
  6. Re: Aftermarket LED Tail light problems
    Sep 2012
    Kent
    Thats great thanks. It would seem that Longman is the nearest person to me. If you could PM him I would really appreciate it. I bought them from a reputable Porsche Specialist and specifically asked if they would work straight from the box! Either they didn't know themselves or they just wanted the sale, either way I won't be back there in a hurry.I drove 40 miles to collect them so I could fit them this weekend as well!!!
  7. Re: Aftermarket LED Tail light problems
    46 Post(s)
    longman hasn't been on since 2009 - is there anyone else near?
  8. Re: Aftermarket LED Tail light problems
    Sep 2012
    Kent
    The next nearest person is Lemonslap. Thanks
  9. Re: Aftermarket LED Tail light problems
    46 Post(s)
    now pm'd
  10. Re: Aftermarket LED Tail light problems
    Sep 2012
    Kent
    Just a quick update, I have sorted the problem now.It turns out that it was the exact opposite to what you guys said. I found a local guy with VCDS and my car was already set to Highline for LED lights,as my old lights were the genuine ones with LED brake lights. When the car was coded to standard lights,Lowline, the new lights worked. I take back what I said about the supplier as these would've actually been Plug & Play if I had normal lights as standard.
  1. Led rear tail light repair
    By mrmarc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2015, 06:07 AM
  2. LED tail light bulbs
    By ChA6dders in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2012, 07:57 AM
  3. Audi A4 B7 LED Tail-light...opinions please?
    By gebbel in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-08-2010, 09:17 PM
  4. Question Mk5 GTi Tail Light LED
    By MartynH in forum Chat - Anything with wheels
    Last Post: 13-10-2008, 12:46 PM
  5. tail light - LED
    By snypa2k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2008, 09:45 PM
