Thread: strange tube
  1. strange tube
    Sep 2012
    harlow england
    i had the gap between the engine buikheads where the battery sits fill up with water and freeze so dead battery on replacing i noticed a clear tube in a black coragated outer laying behind the battery where does the end of the tube go and what does it do as at present it apears to come off a connection somewhere since the flood the centrall locking is not working and the central dash display characters apear broken up the car is a a4 2000 w reg
    ihope someone can help a the car deserves saving regards mrplastic
  2. Re: strange tube
    6 Post(s)
    You've found the the plenum chamber.
    Take the battery out and thoroughly clean the area with a light detergent and plenty water. The water drains down the front of the bulkhead and onto the under trays, then onto the road. The rubber grommets are prone to blocking with leaves, etc. When blocked the brake servo or ECU can become submerged. Personally I'd remove the grommets, or at the very least cut them down.
    i think the tube you're referring too is the drain under the wipers. That water drains into the plenum chamber.
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  3. Re: strange tube
    Aug 2011
    Meath
    Some batteries have an expansion tube too
  4. Re: strange tube
    Jan 2010
    southport
    If its a small gauge clear pipe with a black outer sleeve.The clear pipe fits on the breather elbow on the right hand side of the battery.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  5. Re: strange tube
    Aug 2011
    Meath
    That's what I meant!
    Quote Originally Posted by HAWKS View Post
  1. Question What is this tube for?
    By DAN6 in forum Polo - Derby - Lupo - Fox
    Last Post: 07-06-2010, 02:11 PM
  2. Burnt Tube
    By Fred Thornton in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-07-2009, 08:27 AM
  3. Total Eclipse of the Heart - YOU TUBE - YOU TUBE...
    Last Post: 26-06-2008, 11:59 AM
  4. Breather tube on 1.4 Please help
    By Basscrazy in forum Golf MK4 - 1999 - 2004
    Last Post: 07-04-2008, 09:52 PM
  5. Mystery Tube
    By andrewaudi in forum 80 - 90
    Last Post: 28-03-2008, 07:53 PM
