Thread: Steering problems (STRANGE ONE)
  1. Steering problems (STRANGE ONE)
    Dec 2012
    Hampshire
    Hi all. I brought a skoda Fabia 2 and i have had absolutley no problems with it up to today, I went down the tescos and jumped in the car and reversed the car out. The car would then only turn right. you can bring the wheels straght again but and move it right with no hassle what so ever but when you move it from the central possition to move left it just locks and will not move. I have tried it with the igniton off as well but what ever you try and do it will not move left. Both the wheels move right with out a problem.. I took the track rod ends off the wheels and i get the same thing.. I have had a long chat with skoda and all the say is its the rack so i went out this afernoon and got a new rack for it. and fitted it but it does the same thing. Even with the engine off. I can not seem to work it out. anyone got any ideas ???
    Any ideas would be gratfull recieved or any problems you had had there are no lights on the dash or anything so i am really stumped as i was told there was a steering fault light
    so even the ECU does not think there is a fault..
    The last resort i can think of is disconnect the pipes for the rack for power steering and see if that helps.
  2. Re: Steering problems (STRANGE ONE)
    Dec 2007
    8 Post(s)
    Quote Originally Posted by Jamie1980 View Post
    When rods were disconnected was steering column freely turning both ways. Were both suspension swivels turning freely
    Regards
    Michael
  3. Re: Steering problems (STRANGE ONE)
    Dec 2012
    Hampshire
    no even when rods where disconnected it still locks up and both sides move freely... I have been told its hydrolicy locked up on the left hand way...
    i have taken out the 19mm bolt that holds on one of the pipes buit still nothing i would of thought that would of released it..
    any ideas...
  4. Re: Steering problems (STRANGE ONE)
    Dec 2007
    8 Post(s)
    any ideas...
    Only thing that comes to mind is joints on steering column. but when rack was removed it probably would have been evident if anything was amiss.
    Hopefully someone will come along with solution for you.
    Could it be steering lock problem. Was steering on full lock when car was parked.
    Regards
    Michael
  1. Strange Steering wheel off center?
    By steeevo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2010, 06:50 PM
  2. Strange steering/wheel noise
    By denkatenka in forum A8 - S8 - V8
    Last Post: 11-02-2010, 02:10 PM
  3. Please Help Steering strange
    By BlueCaddy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2008, 09:09 PM
  4. Strange Knock(tap) on steering - could it be serious?
    By rodd1000 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-07-2008, 09:08 AM
  5. power steering problems and a strange warning light
    By davidh2316 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2008, 04:59 PM
