Thread: 2.0 20v petrol "BAD" fuel consumption
  1. 2.0 20v petrol "BAD" fuel consumption
    Dec 2012
    northumberland
    Hey i own a passat 2.0 20v petrol sport 52reg i have owned this for about a year now and the fuel consumption is getting considerably worse. I used to get roughly 100 miles to £20 which is about 400 miles to a full tank which is £80 which i was quite happy with. Now i am lucky if i get 50 miles to £20 and 250 miles max to a full tank just wondering if anyone else had come across this or any one know how to fix this issue.
    thanks in advance.
  2. Re: 2.0 20v petrol "BAD" fuel consumption
    You can't compare miles to quids, its dependant on fuel price and fuel has gone up, miles/litre or miles/gallon is the way to go!
    If you get it perfect it will still be rubbish compared to a 1.9tdi, 54.6MPG from mine over the last 2 years!
  3. Re: 2.0 20v petrol "BAD" fuel consumption
    Gwent
    A good starting point, is the coolant temp sender, if it is misreading it may be keeping the car in cold enrichment mode? You could see with VCDS, look at coolant temp in measuring blocks.
    Another possibility is lambda sensor, not sure which type passats use, but it is usually possible to test with a multimeter. go to Just Lambda, Suppliers of Bosch and NTK lambda sensors including zirconia and titania sensors by post
    I'm guessing it will have a air mass meter or 'MAF' sensor after the airbox, this could also be at fault.
    A fault code read may throw up something useful, but does not always tell you exactly what to change.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: 2.0 20v petrol "BAD" fuel consumption
    Jul 2010
    Brighton
    Good shout on the post above,
    I 2nd the coolant temp sensor they are reknown for poor fuel consumption, failing that I would start looking at the MAF
  5. Re: 2.0 20v petrol "BAD" fuel consumption
    Feb 2010
    luton uk
    i had this prob last year on my 2.0 l auto about 6 months after a timing belt change and after changing pretty much everything it turned out to be 4 rocker cover bolts were loose , whether the mechanic left them loose or if they vibrated loose i have no idea but after tightening them up it ran perfect for an hour till i hit an audi up the rear in an insurance scam (not my ins ) and wrote it off.
    i replaced the following
    2 lambda's
    1 cat
    air mass meter
    plugs
    leads
    various pipes
    coil pack
    secondary air motor
    coolant sensor
    thermostat
    if you do a search on my name you'll see loads of posts for fuel consumption
    "A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
    Winston Churchill
  6. Re: 2.0 20v petrol "BAD" fuel consumption
    Oct 2005
    Before you start replacing things get the car scanned for any faults that may be present. That way you wont throw away any money that would be better spent on fuel
  7. Re: 2.0 20v petrol "BAD" fuel consumption
    Feb 2010
    luton uk
    i scanned mine everytime the management light came on and everytime it was different , sometimes it went from being lean to being to rich and back in a day ?????? all cos of loose bolts .but totally agree with sam and get it scanned
    Winston Churchill
  1. Please Help A4 2.0 Auto Petrol "Hunting Issue"
    By Ski_haggis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2011, 02:07 PM
  2. Question "R"Reg 1997 Audi A4 B5 1.8 SE Petrol - Fuel Pump
    By Joe an his audi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2009, 01:08 AM
  3. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  4. "do tyres make a difference to fuel consumption"?
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2008, 10:12 PM
  5. Distance wid (that's "with" to most of us) around £20 worth of Petrol????
    By ss.raju-golf4 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-02-2008, 11:56 PM
