Thread: A6 questions / model problems
  1. A6 questions / model problems
    Dec 2012
    Scotland
    Hi all,
    This is my first post on the forum - I joined a couple of weeks ago.
    I have been looking to buy an A6 avant for some time now and have finally decided on a 2011 A6 1.9 TDI (Le Mans styling).
    This might be a tough quesion - i'm looking for some buying tips such as common faults to look for, any ongoing issue with this particular build/type and views from owners of this vehicle.
    Appreciate any help/advice given.
  2. Re: A6 Buying guide
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by bazzab1975 View Post
    Hi all,
    A 2011 car will be the C6 variant, so it's worth asking the mods to move this thread over there for you. You won't find a 1.9TDi though - the last A6s with the 1.9 engine were the C5 models, which were replaced by the C6 in 2004. If you're looking at a 2011 car, it's probably the 2.0TDi engine, which is a Common Rail (CR) engine by then. These were available in 136BHP TDIe and 170BHP TDI variants, although I think the Le Mans (or S line Special Edition as they were rebranded) only came with the 170 engines. These seem to have very few faults - I drove a CR170 TDi A6 C6 for three years / 60,000 miles, and the only mechanical issue was a faulty exhaust gas pressure sensor which was replaced under warranty.
    On an Avant, look in the boot behind the panel on the left for any signs of the washer pipe leaking washer fluid onto the radio unit housed in there.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    1 1 0
  3. Re: A6 Buying guide
    Sep 2011
    Lurking over a keyboard ...
    Hi ...
    Welcome to VWAF!
    The facelift models have most if not all of the pre facelift issues solved... as stated by Mark the Achilles heal of Avant is the rear washer pipework...
    The only thing else to mention is as it is MMI 3G there is an update think concerning navigation prompts... if I find thread will link or perhaps another will for you ...
    Other than that happy ...
    ATB
    Gup
    PS Go for Xenons with the inbuilt LED DRL's as they look sooo cool! also the MMI 3G can come with a HDD signified by a joystick in the centre control knob on MMI panel...
  1. Question My 1999 1.9TDi 110bhp model... A few questions...
    By mboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2011, 10:23 PM
  2. Question VAGCOM/high spec model options - few questions
    By hartry in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-09-2009, 10:23 PM
  3. 2000 model Polo starting problems
    By Mr S.A. in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 01:42 PM
  4. Maf problems on Passat tdi 2000 model
    By mikemate in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 03:43 PM
  5. 2006 model 1.6 gearbox problems
    By longboyad in forum Beetle 2000-
    Last Post: 21-09-2006, 09:20 AM
