Thread: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Feb 2013
    cannock
    hi new to this just wondered if you resolved your promblem our a6 has the same issue thanks mart
  2. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Feb 2013
    cannock
    hi new to this just wondered if you sorted it ? our 08 a6 bre engine code has the same issue.thanks.
  3. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    I replaced the fuel filter and it resolved the issue, hope this helps
  4. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Feb 2009
    Glasgow UK
    Hi all,
    I had my car in at Audi today, as some of you know I've been suffering with hard starts / poor cold starting that gives a 15-20 secs jerky feel, quite scary until she settles down with a light rev to 2000 rpm.
    I've also had a judder that appears when in high gears and at low revs, the car judders quite violently and I've been advised to replace the in tank fuel pump at over £550 by Audi
    This can be driven around / avoided and rather than try to push through it, I've always came off the gas and changed down, no issues.
    Well, with no other recomendations, I decided to try changing the fuel filter and also the glow plugs to see what effect if any that would have, couldn't hurt so lets see......
    Please see glow plugs detail below...
    NGK CZ301 7V K6Z8C
    VW AG N10579803
    I'm no expert on glow plugs but having read a lot about them, they look to be an item that aren't either necessarily good or bad, but they weaken and lose their effectiveness over time. At over 101k miles perhaps mine are due for replacement I thought, so lets see....
    Anyone with any glow plug knowledge or experience please feel free to chime in and advise what looks to be good or bad in the pics above, it could be quite helpful for others.
    The other item was the fuel filter.
    My car is looked after and anything she needs she pretty much gets. Audi recomend filter filters be changed at 40k miles
    I used to cover stellar miles, mainly motorway and around 50k - 70k per year, this has now changed to around 10k-15k and mostly stop/ start around town.
    My last filter was changed at 79583 miles and I'm currently at a little over 101k miles, so its done just under 22k miles, so should be good right?
    WRONG!!
    Mines was BLACK and contaminated with oil
    I asked Audi to keep the old fuel filter for me, but they didn't, they did one better and made me a video to share with you all showing the fuel that came out.
    See link below....
    You will need a pin to view, please use the following bearing in mind its case sensitive
    ec3cf76e
    Click here
    You can clearly see the black covering of oil in there.
    I haven't had any dodgy fill ups as far as I'm aware? I used to use Tesco fuels, but changed some time ago ( around 9 months ) and now only use Shell Vpower diesel
    Driving home from the dealers I noticed instantly a huge improvement in pulling power, she was ready n eager all good to go, pulling like a train, always a good sign.
    I did try and check several times for the jerky / judder, lumpiness and it seems to have disappeared . It may be too early to tell so I will watch for any signs of this and report back as necessary over the coming days / weeks / months.
    As for the glow plugs?
    I'm not 100% sure if they've made a difference tbh.......Again, I'll check and report back on this
    At a cost of £265.93 its all good as far as I'm concerned at the moment and money well spent.
    Thanks Stirling Audi
    Audi advise that there may be an issue either with my injectors / tandem fuel pump that could be causing the oily fuel as seen in the filter and I know thats £££ to fix........I'll be doing further checks.
    The thing is I actually had all 4 injectors and the tandem pump replaced under warranty some time ago in 2009 due to issues I was having at that time. Should these need doing again at any point and as a customer who has bought the car from new, had all service and warranty work done there, also own a Passat I'll be speaking to customer services and looking for a major contribution, if required.
    Hope this post is useful and helps someone else
    Jim
    1 1 0
  1. Supermarket Diesel Passat B6 2.0 TDi BKP Engine Poor Power Lack of power
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2012, 11:29 AM
  2. Rough running, hesitation and lack of power sorted
    By abimogen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2011, 03:31 PM
  3. 2.0 TDI hesitation power fluctuation
    By spookey in forum Golf MK5 - 2004 - 2009
    Last Post: 17-02-2010, 02:09 PM
  4. 2.5 TDI misfire/hesitation
    By slarti in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2009, 09:22 AM
  5. 95 TDI hesitation / misfire / stutter
    By The Noble Gnome in forum Early Passat Forum - Pre 97
    Last Post: 17-08-2009, 08:34 PM
