Thread: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
Results 1 to 10 of 14
  1. Question 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    2008 A6 2.0 tdi bre engine , hesitation , slight misfire, lack of power above 3000rpm driving 3rd 4th 5th 6 th gear , higher the gears more noticeable , won't rev out , no fault codes , fuel filter replaced 30k miles ago timing belt changed 5k miles ago , timing marks rechecked ok , new air filter , static vehicle the engine revs out ,
  2. 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    46 Post(s)
    Change the fuel filter and get it scanned with vcds
    1 1 0
  3. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    Will change filter thanks in advance post back , is vcds Scanner available to purchase ? , regards , ken
  4. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Jul 2007
    glasgow
    35 Post(s)
    check mass air flow meter as well. Below certain revs , the car will drive fine ; and then in higher revs it fails leading to loss of power as your feeling. It will probally reset itself when you switch ignition off.
    1 1 0
  5. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    May 2009
    Stirling, Scotland
    Is there any 'whooshing' noise in the cabin from the passenger side under acceleration as well? Same symptoms occurred with mine a few years back and it turned out to be the intercooler. Oild around the fuelfilter is another sign, with intermittent power, misfiring and free revving ok in neutral.
  6. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    No whooshing noise , no oil leaks , car has only done 85k miles , timing belt was replaced at 80k by myself , rechecked marks ok , tks
  7. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by kenmurray View Post
    Bought mine from Gendan... great product, invaluable to a VAG owner IMO... Link:- http://www.gendan.co.uk/product_VCHU.html
    Free updates, email support, etc,etc...
  8. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    The fuel filter was partially blocked, replaced it and that fixed the problem , thanks to all for their replies
  9. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    Feb 2009
    Glasgow UK
    Hey Ken, I'm intruiged by your post and have similar issues I believe on my 2007 A6 2.0 Tdi remapped.
    It generally seems to happen in higher gears but at lower speeds and there is a juddering / shaking that can be felt, its quite violent and I usually change down to alleviate this. I have no codes at all and the car otherwise seems to run fine.
    One thing I did notice today though as I was on the motorway I decided to open her up to loosen the cobwebs and she seemed a little underpowered?
    As with you the car has been serviced recently including new air filter, oil filter + oil change as well as fuel filter.
    I'm hoping that it may be something as simple as changing the fuel filter but don't know if I hold out much hope of it not being something more serious.
    It's going in to Audi on Friday for a road test and I may get them to scan it too and see what it shows up, perhaps replace the fuel filter. I've had thoughts of DMF or injectors running through my mind so I'm a little concerned to say the least.
  10. Re: 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    ireland
    Yes the fuel filter was partially blocked , as I blew through the supply line on new filter and compared to old filter , definate difference was noted , changed the filter anyway and it drives like normal no with no hesitation or misfire , it's the cheapest and best option to replace the fuel filter , any blockage will starve tandem fuel pump of adequate amounts of fuel thereby starving the injectors of correct quantity of fuel on demand ,
  1. Supermarket Diesel Passat B6 2.0 TDi BKP Engine Poor Power Lack of power
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2012, 11:29 AM
  2. Rough running, hesitation and lack of power sorted
    By abimogen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2011, 03:31 PM
  3. 2.0 TDI hesitation power fluctuation
    By spookey in forum Golf MK5 - 2004 - 2009
    Last Post: 17-02-2010, 02:09 PM
  4. 2.5 TDI misfire/hesitation
    By slarti in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2009, 09:22 AM
  5. 95 TDI hesitation / misfire / stutter
    By The Noble Gnome in forum Early Passat Forum - Pre 97
    Last Post: 17-08-2009, 08:34 PM
