Thread: MMI Oil Display - What exactly does it display?
  1. MMI Oil Display - What exactly does it display?
    Jul 2012
    United Kingdom
    A questions about the MMI oil display. The oil display on my MMI was close to Min so I took this to mean the oil was nearly empty (which i thought was weird since I have only covered around 5000 miles since last service, but the manual does says it can use 0.5L per 1,000 KM / ~621 Miles).
    However, after filling with 1 litre, the bar is back to full? I've been reading around and some posts mention that the display is only for the top 1qt of oil in the tank and not the actual amount left in the tank?
    This makes no sense to me as how are you actually supposed to know what is physically in the tank with no dipstick? The manual has no mention (from what I can see) that the display is not the actual reading of the oil levels in the tank. it just states 'Top up the engine oil if the bar in the oil level display is near the “min” mark'.
    Can anyone definitely state what the display actually shows i.e was my tank nearly empty (in theory I could put more oil in) or was it just down 1qt?
    Thanks,
  2. MMI Oil Display - What exactly does it display?
    46 Post(s)
    You can retrofit a proper dipstick if you do a search
  3. Re: MMI Oil Display - What exactly does it display?
    Jul 2012
    United Kingdom
    Thanks, I'll take a look around. I wanted to know around the limits to make sure I have not overfilled and for future reference. It's annoying that they decided to take the dipstick out and not just have both options.
  4. Re: MMI Oil Display - What exactly does it display?
    Aug 2010
    Leicester
    Quote Originally Posted by _tones View Post
    The min/max on the MMI are equivalent to the min/max marks on a dipstick
    i.e when the MMI shows min it's not equivalent to taking the dipstick out and finding it doesn't touch the oil at all
    2017 A5 sportback, 2.0TFSI, quattro, S tronic, S line, virtual cockpit, mythos black.
  5. Re: MMI Oil Display - What exactly does it display?
    Jul 2012
    United Kingdom
    ah, ok. Thanks for the clarification. I'm just not sure how much the difference between Min and Max is but at least I know it's not a tank. Makes more sense now as I expected to fill up a lot more than a litre when it read close to Min.
  6. Re: MMI Oil Display - What exactly does it display?
    Aug 2010
    Leicester
    I think it's 1 litre, if you go below min I understand you get a warning light (and/or message that says "add 1 litre of oil"), but I'd add it slowly say 250ml at a time and see how it changes the display
  1. MMI Display
    By Matt482 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-08-2012, 09:07 PM
  2. Probrem with MMI display
    By Stevef1968 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 19-01-2010, 12:56 AM
  3. Question Audi A4 MMI Oil Level Display Problem
    By DougC in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-01-2010, 07:13 PM
  4. Question A4 B8 Problem of Oil Level Display in MMI
    By nordi33 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-02-2009, 12:30 PM
  5. Question MMI Display
    By Aljo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2008, 10:48 AM
