Re: Lost clock MMI screen aftere activating battery level indication in hidden menu –
08-12-2012,03:46 PM
It sounds like you may have inadvertently changed the option for setting your clock time when you were in the hidden menu. Some C6s had the option to set the clock from a radio signal, but your hardware may not support that. Is it possible you have switched this option on while going through the menus? If you can find the option you changed, try setting it back...
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
