Thread: Oil filter won't unfasten
Results 1 to 10 of 10
  1. Angry Oil filter won't unfasten
    Dec 2012
    A, A
    Hi People!
    I am new to the forum, and came with a big problem...
    I changed my oil today, and wanted to change oil filter as well...
    It was so tight that I went back to Halfords and got a wrench with a rubber band, but didn't work either, it was slipping all the time.
    Then I got the proper Laser oil Filter Cup, and surprisingly I could not open it.
    At a certain point I thought I was pushing the wrong direction but not, I've seen the arrow that shows "45nm" to the right side, so I was doing right.
    The filter cup is plastic and has a little wear on it from previous use, but not too much.
    Last service I did with Audi, but as it's too expensive, I doing by myself...
    I can't imagine how they fasten it so tight??
    Isn't it supposed to be really easy to unfasten?
  2. Re: Oil filter won't unfasten
    May 2009
    Saddleworth, Yorkshire
    Not wanting to imply anything but......I don't think you are undoing the right part if you are using a wrench with band, as all you need is a large socket pref 6 sided. From memory I can't remember the size I think its about 30 mm.
    The housing cover is made form black plastic with a large 'O' ring so don't need to be mega tight.
    You remove the cover from the top of the engine, and the housing is on the right of the engine block. You remove the black plastic top from the filter housing and change the filter cartidge thats inside.
    This is a picture of the housing, but in the photo its on it's side with the top to the right, but you can clearly see the black cover with the hex head.
    AUDI A4 B7 2.0 TDI Oil Filter Housing Plate Mount Cooler 2005 - 2008 045115389E on eBay!.
    Hope this helps a bit
  3. Re: Oil filter won't unfasten
    Dec 2012
    A, A
    Quote Originally Posted by ihs61 View Post
    Thanks for your reply!
    The wrench with the band was my first attempt, the I bought this: Halfords | Laser Oil Filter Cup Wrench 76mm
    tried to unfasten, but couldn't, that's where I got more worried.
    My filter is simlar to that in the picture but hasn't got the hex head, actually the hole head is where you fix the key to unfasten.
    And, there is not much room to engage the socket onto and I'm afraid to break the hole thing...
  4. Re: Oil filter won't unfasten
    Sep 2008
    6 Post(s)
    Whoever put it on probably over-torqued it. The Laser hex oil filter tool with a 1/2" drive and it will easily shift it. Remember to use a smear of fresh oil on the gasket before tightening the new filter.
    2016 BMW i3 REx (80k)
  5. Re: Oil filter won't unfasten
    Sep 2008
    chester
    17 Post(s)
    Run that past me again which way are you turning it clockwise or anticlockwise.
  6. Re: Oil filter won't unfasten
    Oct 2012
    uk - york
    Hi, should be ant-clockwise for off, do it when the engine is hot, should help you remove it easier, good luck.
    2004 VW Touran - Engine AZV 2.0 litre TDI
  7. Re: Oil filter won't unfasten
    Dec 2012
    A, A
    Quote Originally Posted by nevo View Post
    I am turning it anti clockwise.
  8. Re: Oil filter won't unfasten
    Pembrokeshire
    22 Post(s)
    its obviously been overtightened last time. thing is, theres an o ring that does the sealing, the tightening is only to stop it coming undone, not to seal it. now, before going further, i would obtain a new one, then use whatever means neccessary to remove the old one. i use a pair of oil filter pliers that will grip the outside and remove even the almost most stubborn ones, but you may break it, but since you already heve a new one, it doesn't matter, plus the new one isn't worn so the proper tool you have purchased will shift it. a 3 legged oil filter remover may also shift it. you might be best taking it to a garage and get them to just loosen it for you, or remove it and pop your new one on for you.
  9. Re: Oil filter won't unfasten
    Sep 2008
    chester
    17 Post(s)
    Some of the cheapo cap removers will by time you,ve put the 3/8 drive in it bearly fits over the cap,try welding an old socket on it, and use two types at once,as above dont be affraid of butchering it,buy a new one or go the scrappy,obviousley some dim wit has overtightened it.
  10. Re: Oil filter won't unfasten
    Get your engine up to operating temperature.
    It'll come off easier then.
    G.
    Get educated or get ripped off!
  1. oil filter removal during oil change
    By jalz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-08-2011, 08:54 PM
  2. Slight oil leak foward of oil filter 1.8T
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2010, 09:44 PM
  3. Po;o 02:How do I get the Oil filter element away from the filter body ?
    By Dan Gurney in forum Polo - Derby - Lupo - Fox
    Last Post: 12-02-2009, 07:46 PM
  4. Audi A3 2004 2.0 Sport Oil filter and oil change
    By kav_121 in forum Audi A3 - Archive Topics
    Last Post: 12-11-2008, 02:55 PM
  5. oil filter, oil pump. turbo or engine- You decide!!
    By jonny williams in forum Chat - Anything with wheels
    Last Post: 15-04-2008, 01:29 PM
