Thread: golf mk4 1.4S, drivers side door central locking problem
  1. golf mk4 1.4S, drivers side door central locking problem
    Dec 2010
    leeds, UK
    Hello,
    My 2002 1.4S Golf (with central locking) recently started having problems with the drivers side door.
    When I turn the key in the drivers lock all the doors lock fine. When I unlock, all the doors unlock, apart from the drivers door which usually requires a couple more turns of the key to get it to unlock.
    Then today, I noticed that when locking/unlocking there is a growly gravelly noise coming from the door lock mechanism.
    Pressing the lock button inside locks/unlocks all the doors fine, as far as I can tell.
    I'm about to take it to the local VW specialist (Volksworks in Leeds), who are very good and never charge for work that doesn't need doing, but I'm still wondering if this is something I could do myself and save £100 or so.
    Thanks for your help!
    Cheers, Ben.
  2. Re: golf mk4 1.4S, drivers side door central locking problem
    Dec 2007
    Belfast
    It could be a failing door lock.
    When you are in the car with all the doors closed, is the door open icon on the dash or if you are in the car with all the doors closed and you open the drivers door, does this light come on ?
    Marko
  3. Re: golf mk4 1.4S, drivers side door central locking problem
    Dec 2010
    leeds, UK
    Hi Marko,
    No lights on the dash when all doors closed. When I open the drivers door, the light comes on.
    I noticed last night that if you open the passenger side lock, all doors unlock apart from the drivers, which has to be opened from that side.
    Many thanks for your help!
    Cheers, Ben
    Quote Originally Posted by belfastmark View Post
    Marko
  4. Re: golf mk4 1.4S, drivers side door central locking problem
    Jul 2007
    Quote Originally Posted by eurobenjy View Post
    Hello,
    Cheers, Ben.
    if you got vcds or vagcom diagnostics,this will pinpoint the fault
  1. Question Drivers side central locking solenoid
    By CNPrior in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-01-2013, 10:43 PM
  2. Please Help Drivers Door Lock/Central Locking Problem
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2011, 03:38 PM
  3. MK4 Central locking & window problem (rear passenger door)
    By Green MKIV in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2010, 09:16 PM
  4. Mk4 golf w reg drivers side lock problem
    By oggies30 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-12-2009, 02:02 PM
  5. Central locking unlocks all except rear door drivers side
    By mattym in forum Bora - 1998 - 2005
    Last Post: 22-04-2009, 01:39 PM
