Thread: rough idle once engine is warm
  1. rough idle once engine is warm
    Oct 2012
    Dunoon
    ok so i replaced the ht leads and spark plugs, cleaned the inlet manifold, cleaned then reprogrammed the throttle-body, ran injector/engine cleaner fluid through the engine i rescanned and im getting an error referring to the the power steering pressure switch grounding to earth, so i disconnected the switch and sprayed a bit of wd-40 and then a quick clean, followed the wires and noticed that they had been broken at some point, so i got them fixed with the crimping tool and fixed them, i then rescanned and nothing has came up..
    when the engine is running its fine but once the engine heats up it idles pretty crazy yet doesn't loose any power, the only thing i can think of is maybe replace the power steering pressure switch, also the induction pipe that runs from the maf sensor to the throttle body is fine, but the little pipe that connects to the oil/camshaft breather is screwed (melted or collapsed on itself) so i opened it back up and electric taped it to seal it again, is this pipe pressurised when the engine is running ? im just wondering if i should replace it or leave it, i see hundreds of other people with the akl engine seal it with electric tape as-well
  2. Re: rough idle once engine is warm
    134 Post(s)
    2007 Post(s)
    Which diagnostic system do you have?
  3. Re: rough idle once engine is warm
    Oct 2012
    Dunoon
    i have vcds lite+an eBay cable, and a fox-well auto-master, iv also taken it round to my friends who scanned it with full vag com
  4. Re: rough idle once engine is warm
    134 Post(s)
    2007 Post(s)
    You need to do a learnt values erase and a throttle body adaptation and for that you would need your copy of VCDS Lite registering with Ross Tech which costs $99.
  1. Please Help Tapping sound while engine warm and idle??
    By giggsy07 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2012, 04:21 PM
  2. Idle rough on warm-up
    By patrickhorton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-11-2011, 04:46 PM
  3. A4 V6 2.8 Engine 1998 Does NOT idle when warm
    By mumutley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-08-2011, 09:08 PM
  4. 1995, 1.8L 8v Idle problems on engine warm up
    By GixxerR in forum Golf MK3 - 1993 - 1999
    Last Post: 11-05-2009, 11:12 PM
  5. Erratic engine idle when warm
    By ck73 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-10-2006, 08:22 PM
